Old 11-23-2020, 07:19 AM
smallstonefan smallstonefan is offline
Default iPad Control just changed to Version Mismatch
Hi all,
I have a problem that just started. I have a pair of S1 units and a dock. The S1 units each have a Kindle Fire and I'm using an iPad air for the dock.
Everything has been working fine up until now. In EuControl, The status of the iPad is listed as Version Mismatch. I have updated the iPad software and re-installed Avid Control, and I downloaded and installed the latest EuControl software but this persists. It will not allow me to add this to My Surfaces with the issue.
Again, everything was working fine and I don't believe anything changed.
I welcome any help ya got! :)
James
Old 11-24-2020, 10:58 AM
Default Re: iPad Control just changed to Version Mismatch
So even thought the Apple App store says that there was a new version of Avid Control put out 5 days ago (22.11.0), even with an uninstall, reboot, and fresh install on my ipad I still am running version 2020.11.0.9.
Does anyone know if this is correct? It seems like this failed about the time the new app came out.
Is there a way to roll back to 20.6.0 on the iPad?
Old 11-25-2020, 08:56 AM
EddieJones's Avatar
The current version is 2020.11. You need to make sure both EuControl and the Apps are updated. You can find EuControl either in your Avid account or the Avid download center.
Old 11-25-2020, 09:23 AM
Hi Eddie,
I appreciate your response. I have updated both EuControl and the app.
I still have the problem...
Old 11-26-2020, 09:48 AM
EddieJones's Avatar
Originally Posted by smallstonefan View Post
Hi Eddie,
Can you please look at the about screen on both and check the exact version numbers for both and report back?
Old 11-26-2020, 11:51 AM
You bet!
EuControl: 20.6.1.3 downloaded from my downloads section.
iPad Avid Control: 2020.11.0.9 downloaded from the Apple store (multiple times)
My Android tablets are working and they are version 20.6.0.1
Thanks Eddie!
Old 11-26-2020, 06:25 PM
EddieJones's Avatar
You need to download EUCON(EuControl) 20.11 and then update the Android tablets to 20.11
Old 11-27-2020, 07:00 AM
Hi Eddie,
I sorted this out with your help thanks!
This was the first time I updated EuControl and when I finally found the download page I just downloaded the latest release in the list, which I realize now was the latest of the previous releases.
Also, the latest iPad install does indeed have a different version number than displayed in the store and that was confusing me. It does work however...
You don't know what you've got till it's gone - losing that one surface was really slowing me down! :)
Thank you!
Win 10 Version Mismatch noiseboyuk Avid S1, S3, Dock and Control App 3 05-06-2020 05:20 AM
Pro Tools Control Version Mismatch (latest versions of Eucon and Control) sonichead Avid S1, S3, Dock and Control App 3 02-19-2020 08:23 AM
Version mismatch error loud neighbor Avid S1, S3, Dock and Control App 3 12-19-2019 09:23 PM
Earlier version of Control for ipad? jjsoundoc Avid S1, S3, Dock and Control App 1 10-28-2017 03:13 PM
Anyone using a iPad 3 with the latest version of Pro Tools control? Trainwreckmusic Avid S1, S3, Dock and Control App 6 03-10-2017 04:48 PM
