Old 08-10-2020, 05:26 PM
digimon666 digimon666 is offline
Default Protools 12 and Apogee One USB 1.1
I'm trying to record using an Apogee One into a Macboo pro 2019. It's powering on and being detected when connected to my Macbook but I'm not able to select as Input in a session as it ghosted grey. I am able top playback audio in the PT session but I'm not able to select record. I have Shure SM 58 hooked up.
The Apogee One is is selectable as an audio device when opening another DAW like Garageband or Logic.
I have followed all the procedures but I still can not see apogee ONE as an input device in protools. Is there a compatability issue. What do I need to do?
Iv'e followed the procedures on this link. I have sufficient ram and harddrive and I'm on a macbook pro 16.
https://knowledgebase.apogeedigital....lletin/macos-1
Any help would be much appreciated
Thank you
Old 08-10-2020, 05:30 PM
Default Re: Protools 12 and Apogee One USB 1.1
Most likely it's not selected as the playback engine Setup>Playback Engine.
If it is then go to Setup>IO>{input,output,bus} and on each page select and delete all paths and press the Default Button.
And try reselecting the input IO on the track if needed.
Apogee AD-16X with X-HD card for ProTools macmusic9 Buy & Sell 4 12-22-2014 11:33 PM
Apogee and Protools Le swalleight Tips & Tricks 2 01-20-2008 11:10 AM
apogee big ben & protools ashish Tips & Tricks 5 08-24-2004 04:32 AM
Apogee AD16x and Protools MartyJB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-22-2004 07:13 AM
protools HD and Apogee AD-DA 16 Brave Noise Pro Tools TDM Systems (Mac) 0 01-26-2003 01:00 AM
