SiSoftware Sandra
ID Host Name : StewCPU Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS SABERTOOTH X79 Serial Number : 1403236******** BIOS : AMI (OEM) 4608 12/24/2013 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz (6C 12T 3.7GHz/3.9GHz, 3.7GHz IMC, 6x 256kB L2, 12MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : ASUS Core (Ivy Bridge-E) DMI2 100MHz Memory Controller : ASUS Core (Ivy Bridge-E) Integrated Memory Controller 0 Target Address/Thermal Registers 100MHz, 4x 3GB DIMM DDR3 1.33GHz 256-bit Memory Module(s) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory PSD34G13332 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory PSD34G13332 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT125U6BFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory PSD34G13332 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory PSD34G13332 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : WDE VR-4025 (1920x1080, 32.1") Monitor/Panel : ACR Acer H203H (1600x900, 26.4") Monitor/Panel : Hewlett Packard HP w1707 (1440x900, 17.2") Video Adapter : AMD Radeon R7 200 Series (14CU 896SP SM5.0 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit, PCIe 3.00 x16) Video Adapter : AMD Radeon R7 200 Series (14CU 896SP SM5.0 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit, PCIe 3.00 x16) Video Adapter : AMD Radeon R7 200 Series (14CU 896SP SM5.0 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit, PCIe 3.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon R7 200 Series (896SP 14C 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit) Compute Shader Processor : AMD Radeon R7 200 Series (896SP 14C 1.18GHz/1.1GHz 6% OC, 2GB DDR5 6.5GHz 128-bit) Storage Devices Samsung SSD 840 PRO Series (512.1GB, SATA600, SSD, SED) : 477GB (G:) Samsung SSD 840 EVO 500GB (500.1GB, SATA600, SSD, SED) : 466GB (C:) Seagate ST3000DM001-1ER166 (3TB, SATA300/600, 3.5", 7200rpm) : 3TB (F:) Seagate ST3000DM001-1CH166 (3TB, SATA300/600, 3.5", 7200rpm) : 3TB (H:) Samsung SSD 840 PRO Series (256GB, SATA300/600, SSD, SED) : 238GB (D:) WDC WD1002FAEX-00Z3A0 (1TB, SATA300/600, 3.5", 7200rpm) : 932GB (I:) CENTON DS Pro (4GB, USB) : 4GB (K:) WIBU - CodeMeter-Stick (41.2MB, USB1) : 39MB (J:) hp DVD A DH16AAL (SATA, DVD+-RW, CD-RW) : N/A (E:) Logical Storage Devices SSD 512 (G:) : 477GB (NTFS, 4kB) @ Samsung SSD 840 PRO Series (512.1GB, SATA600, SSD, SED) System Reserved : 100MB (NTFS, 4kB) @ Samsung SSD 840 EVO 500GB (500.1GB, SATA600, SSD, SED) 3 T (F:) : 3TB (NTFS, 4kB) @ Seagate ST3000DM001-1ER166 (3TB, SATA300/600, 3.5", 7200rpm) 3 T Part (H:) : 2TB (NTFS, 4kB) @ Seagate ST3000DM001-1CH166 (3TB, SATA300/600, 3.5", 7200rpm) SSD 256 (D:) : 238GB (NTFS, 4kB) @ Samsung SSD 840 PRO Series (256GB, SATA300/600, SSD, SED) Black (I:) : 932GB (NTFS, 4kB) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA300/600, 3.5", 7200rpm) CENTON USB (K:) : 4GB (FAT32, 4kB) @ CENTON DS Pro (4GB, USB) CODEMETER (J:) : 39MB (FAT32, 512bytes) @ WIBU - CodeMeter-Stick (41.2MB, USB1) Hard Disk (C:) : 466GB (NTFS, 4kB) @ Samsung SSD 840 EVO 500GB (500.1GB, SATA600, SSD, SED) Optical Drive (E:) : N/A @ hp DVD A DH16AAL (SATA, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : ASUS Patsburg LPC Controller Audio Device : ASUS Patsburg High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : MSI High Definition Audio Controller Serial Port(s) : 1 Disk Controller : ASUS Patsburg 6 Port SATA AHCI Controller Disk Controller : ASUS Asmedia 106x SATA Controller Disk Controller : ASUS 88SE9128 PCIe SATA 6 Gb/s RAID controller with HyperDuo USB Controller 1 : ASUS Patsburg USB2 Enhanced Host Controller #2 USB Controller 2 : ASUS Patsburg USB2 Enhanced Host Controller #1 USB Controller 3 : ASUS ASM1042A USB 3.0 Host Controller USB Controller 4 : ASUS ASM1042A USB 3.0 Host Controller USB Controller 5 : ASUS ASM1042A USB 3.0 Host Controller FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB/IVB/HSW-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB/IVB/HSW-E XMB Ch 1 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : CENTON DS Pro (3.73GB) Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 7 Home Media Center 6.01.7601 Service Pack 1 Platform Compliance : x64 All of a sudden, in the middle of a mix down I get this error. Now any session I open, even after importing to a new session ends up with this error. I've updated Ilok, trashed prefs and all, but I believe its a windows error. Done some research but the answer is not appearing to me. Any ideas? |
Is this happening with specific sessions only, or every session you attempt to run?
Example... If you start a new session from scratch do you still see this error?
~ tom thomas Formerly hobotom Pro Tools Ultimate 2020.12 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
Looks like its the one session. Imported or not.
Somewhere down the road you may get bitten by your mismatched RAM - both manufacturer and quantity.
Cheers,
Take your projects to the next level with a non-union national read at a reasonable rate Demos: brucehayward dot com Source-Connect: brucehayward |
Good call, was supposed to be temporary but life throws curves.
Access violation occured,unable to read location | alian82 | Windows | 15 | 02-20-2016 09:51 AM |
Unable to launch Pro Tools- Access violation, unable to read location 0x000000008 | JaydenLoone | Pro Tools 10 | 10 | 10-25-2015 10:46 AM |
Access Violation occurred, unable to read location: 0x00000000 | jham14 | Pro Tools 10 | 2 | 08-09-2015 05:39 PM |
Access violation occurred, unable to read location: 0x000000003E3FFFBA | pm mastering studio | Pro Tools 11 | 17 | 05-13-2015 03:37 PM |
Access violation, unable to read location. | Soul El | Windows | 3 | 04-22-2013 07:36 PM |
