Old 05-11-2013, 01:36 PM
graveleye's Avatar
graveleye graveleye is offline
Default Punch-in: How are you getting around monitoring issues?
It is one of the most common maneuvers in recording - the punch in or drop in if you will, yet you cannot do it in Pro Tools any more. You can't hear the existing audio on the track you're punching.
What sort of ways are you using to get around this? Difficulty: buying HD is not an option.
Performing the perfect take every time would be great, but anyone who has been doing this for over an hour knows that isn't always possible or we could do everything we need to do with a half track, a mixer and some good mics.
I'm a MOTU user, and I have screwed around with every configuration of CueMix and Pro Tools that I can think of and cannot seem to be able to hear what I need to hear to perform the most common and simple procedure in recording.
I'm over being mad about this because I am stuck with what I have. I've used PT for over a decade and it is what I use. I just want to use what I have and record my music in the logical way I have recorded for years.
GIGABYTE X58A-UD3R, INTEL CORE i7 960, NVIDIA GEFORCE 8400GS, WIN 7, MOTU 896mk3 HYBRID, PT 10.3.2
Old 05-11-2013, 02:21 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is online now
Default Re: Punch-in: How are you getting around monitoring issues?
Under "Track" on the top toolbar make sure you have it set to "Auto Input Monitoring", and not "Input Only Monitoring". If the dropdown box currently reads "Input Only Monitoring", that means your are currently in "Auto Input Monitoring" mode, which is where you want to be. Kind of confusing, but that's how it works. I am still using version 7.4, so perhaps they changed something since then, but there has to be a way to hear the existing audio prior to the punch in point.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 05-11-2013, 04:13 PM
cwsand's Avatar
cwsand cwsand is online now
Yes you can, as mjslakeridge said. Check the Reference Manual - it's all explained there.
Chris
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2020.12.0
Old 05-12-2013, 07:05 PM
As cool as the MOTU boxes are, with my 003, I never have any punch-in or monitoring problems.. One solution for you would be to use playlists, record several passes, and then comp.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 05-14-2013, 07:16 AM
graveleye's Avatar
Well I feel kind of stupid because I KNEW the answer, but had totally forgotten. This system is still relatively new to me. Years of working with the 001, I set the input monitoring on that and never worried about it again. I should have recalled that but it's been a decade now.
I do comp tracks a lot, but in some instances I prefer to do a drop - especially when the musician is tired/fed-up and the song is eight minutes long.
So... I imagine with your 003 you don't have to change it back and forth do you? I learned last night that if you don't change back after your drop you can't hear. So I guess that changing back and forth between the monitoring settings is just one of those inconveniences for 3rd party device users.
Old 05-14-2013, 08:50 AM
This is where the integration of hardware/software has a distinct advantage. I just leave it on Auto-Input all the time. The only time I switch it is for a performer that wants to rehearse something a bunch.
Old 05-14-2013, 09:33 AM
graveleye's Avatar
yea that is how I used to do it too.
I have had a devil of a time adjusting to the disadvantages of having a 3rd party device. I was spoiled with my 001. But the advantages and modern features of PT10 helps to smooth out the bumps.
Monitoring/Punch Question Cal D Pro Tools M-Powered (Win) 2 05-12-2011 02:37 PM
punch in monitoring problem brian crain Tips & Tricks 2 10-30-2010 08:58 PM
8.0.4 Issues (Quick Punch & Mute/Solo issues) pauledwards 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2010 10:35 AM
Overdub / Punch Ins - Double Monitoring Workflow Issues geelo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-16-2008 12:31 PM
Feedback when monitoring punch in earsmiles Digidesign Hardware & Software 2 12-06-2000 08:26 AM
