Long story short, my producer recommended me getting the mbox mini over the regular one saying its just less mic inputs etc..and that he could hook me up with a good deal on it from his buddy at Alto. So I trusted him and bought the non refundable protools / mini and am now 2 hours back home. I now noticed there are no midi inputs. On all my older gear I used to use Logic and do guitar / vox thru the Duet 2 interface, and then plug my Yamaha midi keyboard directly into the tower. [it isn't the 5 prong midi it's the regular usb one]. I am not too familiar with Protools yet...but it looks like I can only choose the Mbox interface. My question is... --- Is it possible to do guitar / vox thru the Mbox Mini interface and have my keyboard midi plugged directly into my computer? And most importantly if so -- would this workflow run smoothly? Thanks |
If your Yamaha keyboard has a usb port, you should be good to go, plug it into the computer and you should see it show up in your list of midi inputs, you may need to install some software [check their website], but usually these type of keyboards work straight away.You might have to go into Setup/Midi/ Input Devices in Protools also to select it as an input device.
ASUS P5k, Win 7, RME Multiface Macpro, 10.8.3, Digi 003 Profire 2626 PT 10.3.6 |
Wait, wait, wait. You have a Duet 2 and he told you to get an MBox Mini?
Why would you need the mbox mini when you have a Duet 2. You just need Pro Tools 10. The Duet 2 is a far superior interface. And if your keyboard has a USB plug you can go right into your computer and use it as a Midi Interface. |
Can't record guitar directly plugged to 003 Factory | Ombor10 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-28-2010 05:19 AM |
USB audio interface works better when plugged in directly rather than through a hub. | lkingston | Pro Tools M-Powered (Win) | 5 | 06-14-2010 10:21 AM |
Yamaha synth>MIDI Channels>Pro Tools.......Yamaha user's LOOK!! | B-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 12-29-2002 01:58 AM |
plugging xlr or 1/4inch directly into computer... HELP | benjaminconrad | Digidesign Hardware & Software | 2 | 05-11-2002 04:30 AM |
Whom may I contact directly about Yamaha CDR 4260 driver progress ? | Chris | Digidesign Hardware & Software | 1 | 05-06-1998 11:47 AM |
