Old 01-29-2011, 06:06 AM
grendizer grendizer is offline
Default trim automation newbie
Hi there
I'm not sure if I fully understood the function of trim automation, I can use some help with it
I finally made the switch from LE to HD and I'm just now getting into all the new features (VCA, multitrack beat detective, ect...). but i have a question about trim automation. In the LE world, if I wanted to turn down the snare track of a drum group. I would uncheck the drum group, go to the edit window, in volume mode, grab the volume line of the snare track with the trimmer tool and pull it down . now, from what I gathered in the reference guide, trim automation is a shortcut to this procedure.
can somebody please give me a step-by-step procedure on how to correctly use trim automation to turn down the snare track?... should it be during play back?
thanx in advance
Mark
Old 01-29-2011, 06:14 AM
Stig Eliassen's Avatar
Default Re: trim automation newbie
Originally Posted by grendizer View Post
Hi there
I'm not sure if I fully miss understood the function of trim automation, I can use some help with it
I finally made the switch from LE to HD and I'm just now getting into all the new features (VCA, multitrack beat detective, ect...). but i have a question about trim automation. In the LE world, if I wanted to turn down the whole snare track of a drum group. I would uncheck the drum group, go to the edit window, in volume mode, grab the volume line of the snare track with the trimmer tool and pull it down . now, from what I gathered in the reference guide, trim automation is a shortcut to this procedure.
thanx in advance
Mark
The trim volume automation playlist works relative to the volume playlist, so with the volume fader at -5 db and the trim fader also at -5 db, the composite volume would be -10 db.
For your example you can use Read/Trim mode, pull down the fader to your liking, and then coalesce the trim automation onto the volume playlist. Just right-click the track name to coalesce. This is one way...
Old 01-29-2011, 06:24 AM
got it! I failed to notice trim volume was now, a new addition to the playlist selection.
thanx
Old 01-29-2011, 08:22 AM
BaileyBass BaileyBass is offline
thanx
Yes, especially if you have a lot of automation written for a vocal, and you want to bring the whole track (or just the bridge) down .5db.. TRIM saves a lot of headaches. Then when you coalesce it s written to your volume automation.
Old 01-29-2011, 08:40 AM
it's very nice indeed. it's awesome how I can do this straight from the mix window, i don't have to toggle. thanx again
soo uhh, VCA, whats that now :)
Newbie Trim Question Skin Getting Started 3 07-13-2013 11:36 PM
Trim automation above plus 12? andydadd Pro Tools TDM Systems (Mac) 1 06-07-2007 09:56 PM
overall automation trim on track,possible? b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2006 07:06 PM
trim automation booboocakesjones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-10-2003 02:13 PM
Trim automation cachemira Tips & Tricks 11 07-03-2003 04:14 AM
