Old 06-13-2010, 04:57 PM
lkingston lkingston is offline
Default USB audio interface works better when plugged in directly rather than through a hub.
I am running M-Powered Pro Tools 8 with Windows 7 64 bit and an M-Audio Fast Track Ultra audio interface. Every so often it would just crash and lock up my computer. I had the Fast Track plugged into a USB hub and I thought I would try not using the hub and going directly into one of the computer USB ports. That was a couple of days ago and it has been rock solid ever since. No more crashes. I thought I would pass this along in case this might help someone else.
laurencekingston.bandcamp.com
Old 06-13-2010, 06:57 PM
Default Re: USB audio interface works better when plugged in directly rather than through a h
OK I spoke too soon. It's still crashing. The crashing is occurring when I use the Alicia's Keys piano in Kontakt. I'm trying a different piano to see if Native Instruments is the culprit. M-Audio interface is plugged back in the hub.
Old 06-14-2010, 06:28 AM
Dism Dism is offline
The hub is still a bad idea...
It is highly NOT recommended to use ANY audio interface through a USB hub. It's still likely that some of your crashes were related to that.
NI also tends to be a problem child with Pro Tools.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 06-14-2010, 07:42 AM
scenicrecords scenicrecords is offline
I had issues just having a hub plugged into the computer for iLok and keyboard. The hub is a bad idea.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Old 06-14-2010, 09:05 AM
I was playing with the Alicia's Keys piano and Kontakt every time I got the crashes. When it crashed it would loop a small section of the audio and nothing else would work. No keyboard or mouse response. No nothing. I've been working without Kontakt loaded and the audio interface plugged into the hub. I'm hearing a little occasional crackling in the M-Audio interface that I believe might be related to going through the hub, but no crashing.
Has anyone got experience using VST versions of NI software through the fXpansion wrapper instead of the RTAS versions? If so, is it less crash prone that way?
Old 06-14-2010, 10:21 AM
From what I hear, wrapping the VST versions is a bit more stable.
I still would NOT recommend using your interface through a HUB though... it's specified in your user manuals, in the troubleshooting section, etc, etc...
D
PT 10 - Can't open PT without my interface plugged in Druvin Base Windows 3 10-04-2013 04:00 PM
Yamaha MIDI plugged in DIRECTLY to the computer tower - possible? thrice506 macOS 2 10-07-2012 07:52 AM
Can I use HD9 with any interface directly? dstar917 macOS 17 11-15-2011 09:33 PM
Can't record guitar directly plugged to 003 Factory Ombor10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-28-2010 05:19 AM
Pro Tools 7.4 works directly with embeded OMF file?! mgoorevich Post - Surround - Video 1 04-11-2008 07:10 PM
