Old 05-26-2010, 08:11 PM
RuffinMedia RuffinMedia is offline
Default Is there a seperate Windows 7 64 PT 8 installer (other than WinXP installer)
OK, I installed Win 7 64 and it looks beautiful however whenever i try install ProTools 8, It crashes halfway through the installation with a Blue Screen. Below is my Sandra report.
SiSoftware Sandra
Computer
Model : Gigabyte H55M-UD2H
Workgroup : WORKGROUP
Host Name : vyente-PC
User : vyente
Processor
Model : Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
Speed : 2.8GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Gigabyte H55M-UD2H
BIOS : Award (Phoenix) F8 02/12/2010
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 4GB DIMM DDR3
Chipset
Model : Giga-Byte Clarksfield/Lynnfield DMI
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : Giga-Byte QuickPath Architecture Generic Non-Core Registers
Memory Bus Speed : 2x 665MHz (1.33GHz)
Memory Module(s)
Memory Module : Kingston 9905403-115A00LF 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : NVIDIA GeForce 6200 LE (2 PS3.0, 2 VS3.0 351MHz, 256MB DDR3 2x531MHz, PCIe 1.00 x16)
Graphics Processor
Storage Devices
WDC WD1001FALS-00J7B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:)
HDS725050KLAT80 (500.1GB, ATA133, 3.5", 7200rpm, 7MB Cache) : 466GB (E:) (F:)
ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm, NCQ) : 1TB
ATAPI iHAS324 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 2GB (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Hard Disk (E:) : 128GB (NTFS) @ HDS725050KLAT80 (500.1GB, ATA133, 3.5", 7200rpm, 7MB Cache)
Storage (F:) : 338GB (NTFS) @ HDS725050KLAT80 (500.1GB, ATA133, 3.5", 7200rpm, 7MB Cache)
Hard Disk (C:) : 931GB (NTFS) @ WDC WD1001FALS-00J7B0 (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
New Volume (L:) : 1TB (NTFS)
3.5" 1.44MB (A:) : N/A
GIGABYTE (D:) : 2GB (CDFS) @ ATAPI iHAS324 A (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte P55/PM55/3400 LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte P55/PM55/3400 High Definition Audio
Serial Port(s) : 1
Disk Controller : Giga-Byte P55/PM55/3400 4 port SATA IDE Controller
Disk Controller : Giga-Byte P55/PM55/3400 2 port SATA IDE Controller
Disk Controller : Giga-Byte JMB368 IDE Controller
USB Controller 1 : Giga-Byte P55/PM55/3400 USB Universal Host Controller
USB Controller 2 : Giga-Byte P55/PM55/3400 USB Universal Host Controller
USB Controller 3 : Giga-Byte P55/PM55/3400 USB Universal Host Controller
USB Controller 4 : Giga-Byte P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 5 : Giga-Byte P55/PM55/3400 USB Universal Host Controller
USB Controller 6 : Giga-Byte P55/PM55/3400 USB Universal Host Controller
USB Controller 7 : Giga-Byte P55/PM55/3400 USB Universal Host Controller
USB Controller 8 : Giga-Byte P55/PM55/3400 USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : Indigita FW322/323 IEEE1394 OHCI FireWire Controller
FireWire/1394 Controller 2 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Mac Mini 2.5 GHz Dual-Core Intel Core i5 - 16gb Mem - MacOS Catalina 10.15.5 - Pro Tools 2020.3.0
Old 05-26-2010, 08:32 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Is there a seperate Windows 7 64 PT 8 installer (other than WinXP installer)
Instructions for installation of Pro Tools for Window 7 and Beta drivers
Good Luck!!
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2020.12.0
Old 05-26-2010, 09:08 PM
TOM@METRO's Avatar
You need PT8.0.3. Which of the 2 interfaces are you installing first?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-26-2010, 10:11 PM
I'm installing the 002R 1st, then the MBox2. I followed the instructions from the Win 7 64 guide. So far so good. I hope this works....
Old 05-26-2010, 10:43 PM
Thanks for everything. I havent done any tweaks yet but PT is running great on Win7 64. :)
9.0.5 Full Installer for Windows? kdubyou Windows 13 05-12-2018 03:48 PM
No protools installer for windows mccoyrare@yahoo.com Pro Tools 10 1 12-28-2013 02:48 PM
The installer was unable to launch the PACE system files installer - Help please buzz302 Pro Tools M-Powered (Win) 3 02-14-2012 10:05 AM
Can't Extract PT8 installer for WINXP !! daveoverreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-19-2008 06:04 PM
DV TOolkit 2 Installer For Windows GamerGee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-23-2006 03:44 PM
