Old 03-23-2010, 12:20 AM
dostacks dostacks is offline
Default Pro Tools installer disc will not launch properly on my system.
I tried to search for similar issues but most people atleast are able to launch their installation.
Basically I thought this was just Pro Tools not working with Windows 7, so once the the problem occured I went to XP Pro SP3, so I think it must have to do with either some driver or hardware component.
The problem is when I go to launch the set up or auto run, a blank grey window comes up and thats it. I know its not the disc because I tried putting the disc into another computer and a splash window with all the options to install comes up like its supposed to. I have a gut feeling it may be my CPU, but haven't found any KNOWN issue, so its driving me nuts! I have been trying to put this rig together for months and finally thought I had it all, but... not so much. ANY help or suggestions would be amazing!
Old 03-23-2010, 12:24 AM
Default Re: Pro Tools installer disc will not launch properly on my system.
Mainboard : Asus M4A785TD-V EVO
Chipset : AMD 785GX
Processor : AMD Athlon II X3 435 @ 2900 MHz
Physical Memory : 2048 MB (1 x 2048 DDR3-SDRAM )
Video Card : ATI Radeon HD 4200
Hard Disk : ST3500418AS (500 GB)
DVD-Rom Drive : TSSTcorp CDDVDW SH-S223C
Monitor Type : ViewSonic VA1703wb-2 - 17 inches
Network Card : RTL8168/8111 PCIe Gigabit Ethernet Adapter
Network Card : AR5212 802.11a/b/g Wireless Network Adapter
Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3
TRYING to install Pro Tools 8 with an Mbox 2
those are my specs btw!
Old 03-23-2010, 01:53 AM
uller uller is offline
Maybe u DVD-Rom Drive has trouble reading the cd
Have you tried to copy the disc to hard disk and then run it from there
Brian Uller
Denmark
Old 03-23-2010, 08:35 AM
Rythameen Rythameen is offline
Had the same problem here with a new computer and ended up copying the disc contents to my desktop and installing from there.
Old 03-23-2010, 03:14 PM
sw rec sw rec is offline
we'll get back to this inevitably so I might as well get it over with now.
You need a second hard drive for audio....
Old 03-24-2010, 11:58 AM
That couldn't possibly be causing my problem I can't even see the menu to install anything, I do understand the importance of a second hard drive though.
Old 03-25-2010, 11:30 AM
So I'm still trying to copy the disc onto my computer, but I'm having nothing but trouble. Its getting to a certain point than giving my a "cyclical error". I'm going to check to see if another dvd rom will work, but after that I found no other known issues that would cause my problem. ANY help in this matter would be great because at this point it looks like I have to take back some of these components or buy new ones which is gonna be a huge hassle.
Old 03-25-2010, 11:32 AM
Just shooting in the dark here, but aren't those discs DUAL LAYER? And if you have a SINGLE LAYER DVD reader, it won't "see" the dual layer discs. Just wondering 'cause I remember the original ZIPPED download wouldn't fit on a single layer DVD....
Old 03-25-2010, 11:44 AM
JMS40 JMS40 is offline
There is an issue with these disc's and certain DVD units. If you are like most with this problem, the install hangs on "data2.cab".
I finally had to extract the disc on my laptop and transfer the files to my DAW.
Old 03-25-2010, 11:46 AM
SW... both the DVD units in my situation are dual layer.
Pro-Tools 8 M-Powered Installer Disc is damaged - HELP! trptman Pro Tools M-Powered (Win) 1 07-14-2013 05:02 PM
The installer was unable to launch the PACE system files installer - Help please buzz302 Pro Tools M-Powered (Win) 3 02-14-2012 10:05 AM
Pro Tools LE 7 version 7.4 installer won't launch crayphish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-22-2011 11:43 PM
Pro Tools LE 7.0 disc installer, ilok problems sean108 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-17-2010 06:48 PM
Unable to launch PACE System Files installer Ab7b9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-17-2003 09:34 PM
