Old 01-08-2010, 02:31 PM
audioluche audioluche is offline
Default All Event markers to warp markers?
I search the 7.4 manual but i dont find a way to do what i want.
Is there a way to turn ALL event markers of a track to warp markers?
I dont want to quantize, the tracks that i am editing right now are not on a click.
I just want to turn all the event markers in one quick operation so i could just listen to the track and warp here and there without having to add a warp marker in warp view, it would be faster.
Am i missing something?
Thanks
Luc
Old 01-08-2010, 02:42 PM
BaileyBass BaileyBass is offline
Default Re: All Event markers to warp markers?
Originally Posted by audioluche View Post
Thanks
Luc
Use Quantize, but set your strength at 0%.... Everything stays.. SB
Old 01-08-2010, 07:26 PM
Hi Bailey,
Thanks for the input.
I tried with the strenght at 0% but the transient seems to be quantized even if it's at 0. And i dont see the warp markers after ...?
any idea?
Thanks!
Luc
Old 01-08-2010, 08:00 PM
Hi Bailey,
any idea?
Thanks!
Luc
hmmm... Are you selecting a portion of audio? 2 bars, a phrase?
Just tested it here and it works as it should, placing a warp marker on every transient, where there was an analysis marker... with strength set at 0, nothing moves.
You are using the quantize window (option-0) right?.. under options (in that window)check the strengh box then pull the slider all the way to zero. And you are in WARP VIEW,
good luck,.. SB
Old 01-10-2010, 04:34 AM
scottgreiner scottgreiner is offline
I usually quantize by 2%, then "remove warp".
Old 01-10-2010, 07:37 AM
Sean Russell Sean Russell is offline
Try this:
In event view (not warp view) do an option-5 and then set the event sensitivity. Helpful if you're EA'ing bass, and don't want all the extra ridiculous markers. (I hope they sort that out).
Then pull up quantize (option-0) and select 1%.
This won't move anything more than a tick or two. It's a very fine amount, and there should be no noticeable difference.
... but does it help the chorus?
Old 01-10-2010, 09:59 AM
midnightrambler midnightrambler is online now
Originally Posted by Sean Russell View Post
T. Helpful if you're EA'ing bass, and don't want all the extra ridiculous markers. (I hope they sort that out).
Yes I concur. What I don't understand is why they have a sensitivity parameter that goes from 0 to 100 but basically nothing happens from 0 to around 90. I end up having to get rid of the analysis markers by hand.
Old 01-10-2010, 10:00 AM
That's what I normally do but I came a cropper earlier on when I "removed warp" as I'd sped the track up 1bpm. We really need a "convert all analysis markers to warp markers" function.
Old 01-10-2010, 11:12 AM
good luck,.. SB
OOPs. I forgot to add that I set Randomize to 1% for the Strength to work at 0. I figured that with strength at zero, then Randomize would not function. I just tested it by pushing Random up... and they do move. So much for "figuring"
I can see zero mvmt at random 1%. I will look further and closer later. Either way the mvmt is less than minescule, insignificant, particularly when dealing with Humans! SB
Old 01-11-2010, 07:02 AM
Ok now it works!
Thanks everybody!
Yes, a convert analysis marker to warp marker would be nice, but that's a good alternative,
Cheers
Luc
Cut at warp markers, is this possible chaeffersa Tips & Tricks 3 12-20-2013 08:00 AM
Lining Up Warp Markers completeidiot23 Pro Tools 10 1 06-14-2012 10:38 PM
How to turn all Event Markers into Warp Markers ??? fman Pro Tools TDM Systems (Mac) 15 04-29-2011 02:46 PM
PT8 Warp markers converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2009 04:40 AM
Warp Markers Inconsistent Mount Royal Pro Tools TDM Systems (Mac) 0 04-17-2008 09:09 PM
