I'm thinking of picking up one of those. I see price is almost double for the TDM Version. Is it worth it?
What are the advantages of the TDM over Native, particular for this plug in? Anybody used them both, or have them both on the same machine?
Pro Tools 11.2 HDX Apogee Symphony I/O 32analog I/O 192 I/O (old) Digital Hack pro i7 Six Core/ 32 RAM Kostadin Kamcev - Mozart www.mozartstudio.com Clifton, NJ |
It's a great plug if you're looking for a clean and transparent reverb that is highly customizable. TDM version naturally has dramatically lower latency so in my book the extra cost is worth it.
That said; I don't use it as much as for example TC VSS3 or Eventide Reverb, but it's still nice to have it available.
Is Latency really an issue with reverb?
I use Waves IR-1 which is only RTAS and it works fine for me.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
RTAS plugs don't have more latency than the TDM versions.
The problem happens when you use them in aux/master channels (or in audio tracks after a tdm plug) because of the streaming from the tdm environment to the cpu and back to the tdm. Therefore in this case the latency depends of how is set the HW buffer in the audio engine. If you set the HW buffer at 256 samples you wll have 512 samples of latency (plus some samples introduced by the plugin itself) that can be well compensated by the ADC set at medium size (1023 samples) but if are running on an old G5 and you want more performance for VI you probably have to set the HW buffer at least at 512. In this case you will have 1024 samples of latency only for the streamings (plus the plugin samples) and especially if you need more comp for inserting other plugs in the chain you will run out of the compensation (medium). You will have to set a higher setting for the ADC that eats more DSPs. I hope this helps
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2020.11 - Cubase Pro 10 Mac Pro 5.1 quadcore 2.8 32GB Ram - Mac OS 10.13.6 |
It is only a problem when you do LIVE projects (or have to provide a monitor mix via PT). Generally artists don't accept +10ms latency, so that means 44.1kHz session latency "glass ceiling" would be 440 samples.
Okay, 256 buffer setting is workable. But it's rather close to the limit. I'd rather take TDM-only session that has effectively "zero" latency.
hi everyone, i got a problem in useing RTAS plugins at aux channel.
my delay compensation setting was long (4095),but when the dly count exceed about 3000samples at the aux channel, the charactor will trun red, what's happened in my aux channel??? |
I have problems with TL space in rtas mode on a aux channel
if I use it in rtas mode I can hear a pre delay I dont hear if I use it in TDM - of course ADC is on in 4096 mode any idea how I can fix this? anyone using TL space in rtas mode without any problems on a HD rig? thx |
![]() Quote:
Instead of the traditional bottle of wine, or tuna casserole (yikes!) allow me to offer two bits of advice, which hopefully will ensure your enjoyment and satisfaction as a DUC member for years to come. Cross-posting (in various DUC fori) and/or multiple posts about the same question/topic is generally frowned upon. The folks around here are generally very helpful and eager to lend a hand (as I’m sure you’ve discovere by now, since you’ve already received two answers). Along the same lines, highjacking a thread by changing the subject to something other than what the original writer intended is also considered bad form. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
![]() Quote:
![]() Quote:
WTB: Sonnox Oxford Limiter | Oliver M | Buy & Sell | 0 | 06-08-2012 02:54 PM |
Sonnox sony oxford elite native vst bundle - need rtas instead | grill229 | Pro Tools 9 | 4 | 04-11-2011 06:45 AM |
Sonnox Oxford | orpheus_2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-04-2010 09:54 AM |
Sonnox Oxford EQ GML Option or MDW Hi-Res Parametric EQ | Keith Moore | Pro Tools TDM Systems (Mac) | 17 | 06-12-2009 03:42 PM |
Sonnox Oxford Plugins only in stereo track, why? | siga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-13-2007 06:47 PM |
