Old 06-27-2008, 02:43 PM
GlennR01 GlennR01 is offline
Default Harpertown/Magma PE6R4: Correct Expansion Slot For Host Card
According to Magma, the correct slot inside your Mac Harpertown (and I quote) is:
"Install the Magma PCIExpress host card in the middle PCIExpress slot (3rd PCI express slot) in the MacPro and then choose the 2nd PciExpress Profile using the Expansion slot utility..."
Doesn't Digi recommend the 2nd PCIExpress slot? Also, the Expansion slot utility would not open, leading me to assume that it doesn't address the host card.
Thoughts? Warnings?
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate
Old 06-27-2008, 03:56 PM
DigiTechSupt's Avatar
Default Re: Harpertown/Magma PE6R4: Correct Expansion Slot For Host Card
Using the 3rd PCIe slot is the way to go -
Video Card
Open Slot
Magma Host card
The Expansion Slot Utility should launch no matter what your card order is, or even if you don't have a Magma card in the computer.
What does it do when you try to open it?
Avid Audio Tech Support
Support FAQ
Old 06-27-2008, 04:58 PM
Touchwood Studios Touchwood Studios is offline
I am using the slot next to the video card - it works good no issues.
Old 06-28-2008, 07:42 AM
Video Card
Open Slot
Magma Host card
It says: "Expansion Slot Utility is not intended to run on this system"
Do know that PT is running fine so far on this system with the cards placed as suggested. Also, I have 2 firewire cards in the surrounding slots (slots 2 and 4).
Old 07-07-2008, 09:45 AM
Video Card
Open Slot
Magma Host card
Which exactly model Mac do you have?
If it's working, I wouldn't worry about it...!
Support FAQ
Old 07-07-2008, 01:39 PM
Mano Mano is offline
TEchsupport,
i have crackles in my audio-playback and posted this in another thread just a few minutes ago. I think its related to these slotorder-confusions. If possible please post a thread with the correct slotorders inside the MacPro for hostcard and Magma for HD cards.
Magma-manual states things opposite to digidesign Expanded Systems Guide according to slotnumbering and in this thread you say slot 3 in the mac is fine...i'm really confuse here and losing precious businesshours.
Old 07-07-2008, 02:09 PM
Install the host card in the lowest numbered PCIe slot in your computer. On a Windows PC, this will be the slot farthest from the graphics card. On a Mac, this will be the slot closest to the graphics card slot.
This is our official slot order recommendation - though it should not matter if you use ours or Magma's suggested slot order.
Slot order in the chassis should have the HD Core card next to the power supply, Accel cards after that and Process cards after any Accel cards.
Pops and crackles sounds like something else. Have you updated all your plug-ins? It is absolutely critical that you only have Leopard/Pro Tools 7.4.2 plug-ins installed.
Support FAQ
Old 07-07-2008, 02:28 PM
ZEUSS ZEUSS is offline
Here is how mine is setup.
Although my mac is the first special order 8 core, I have the Geforce 7300GT in slot one X16. The bridge card is in the 4th slot. I have the first profile selected which is X16 Lane graphics slot+one X8 Lane and Two X1 lanes. This shows both cards running at maximum speed. My core card is in the chassi farthest to the right, followed by the process cards.
It has worked flawless for me for almost a year.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 07-07-2008, 02:43 PM
I have kontakt 3 installed but it is not implemented in the session.Kontakt however, if used , is doing fine inspite of the negative recommendations.
Can this be misbehaving even if not used in session????
Old 07-07-2008, 02:45 PM
the hostcard is seated next to the graphicscard, on Macs motherboard its written X16 beside it.
What is prefered X16 or X4 ?
Magma Chassis host card - which PCIe slot? Allan Speers Pro Tools TDM Systems (Mac) 2 09-07-2012 09:54 PM
Digi branded 13 slot Magma p13R PCI Chassis with PCI host card John_Toolbox Buy & Sell 4 07-28-2012 10:43 AM
New PCIe host card with old Digi 7-slot expansion? Mauro371 Pro Tools TDM Systems (Mac) 2 12-17-2005 03:40 PM
host pci 7 slot expansion card JOHN PAYNE General Discussion 0 03-08-2004 01:45 AM
4 slot Magma correct card order James Thomson Pro Tools TDM Systems (Mac) 1 09-24-2002 06:11 AM
