Old 03-08-2001, 10:20 PM
tomcat tomcat is offline
Default PT 5.1 crashing on delete file command
Pt crashes with a type 2 error every time I try to delete a file from the region bin, (cmnd+shift+B, choose “delete”) anybody else? It wasn't doing this two days ago, but yesterday and today, in two different sessions, it does.
tom
www.tompaul.com
Old 03-18-2001, 06:49 PM
TommyT TommyT is offline
Default Re: PT 5.1 crashing on delete file command
I haven't been able to remove files either with 5.1 It quits every time....I've Done disk Check / Optomize / Desk Rebuild but to no avail....I think this is a bug.....
Old 03-18-2001, 08:30 PM
Tim R. Tim R. is offline
Same problem here. I talked to Digi Tech support about it and he said he hadn't heard of it before. I thought it might be attributed to the fact that the sessions I had it happen in had tracks that were imported from a Digi 001 system. Another factor I thought might have caused the crash was that I had just deleted a slew of tracks from the edit window. It crashed after warning of regions still in the clipboard/undo or something. Maybe it's a problem here? Keep me posted if you resolve it, and call Digi and tell them many people are experiencing this.
Tim
Tim Reisig
System 1: Pro Tools Ultimate 2020.9, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 20.6, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 03-18-2001, 08:55 PM
Paul Greyson Paul Greyson is offline
So, tomcat, are you saying that with these sessions, it's impossible to delete (as in delete from disk, not just delete the region) *any* files? Or just certain files?
And this happens after quitting and restarting the system?
Also, I'm confused: Tim R., you say that you "had just deleted a slew of tracks from the edit window." That makes it sounds like it's only happened once where as Tommy T makes it sound like it happens with any file in any session.
So, I need a little clarification.
Paul Greyson
Digidesign Engineering
Paul Greyson
Old 03-19-2001, 12:33 PM
This happened across 3 sessions all of which I had just removed a bunch of tracks from. All had imported tracks from an 001 system (months ago). I got around it by Deleting fewer tracks at one time. Though sometimes it would crash deleting just one region, but if I went to other regions first then went back to the troublesome track it would delete fine.
Tim
Tim Reisig
Old 03-19-2001, 03:30 PM
I got a crash everytime I did cmnd-shift-B and chose delete or remove. I don't do it anymore. I think these session had tracks and audio imported from a 4.3.1 session. I don't have time right now to crash. Maybe later i beat the system up a little.
tom
www.tompaul.com
Old 03-20-2001, 01:23 AM
Thanks for the clarification Tim R.
tomcat and TommyT, is that consistent with your experience?
Paul Greyson
Paul Greyson
Old 03-20-2001, 06:21 AM
thefly thefly is offline
yes, it happens on my system too. i usually have the region bin files sorted by modification date w/ descending order, so the most recent recorded file is at the top of the region bin. when i hit cmnd+shift+B, pt crashes w/ type 2 error. But, if i don't sort the region bin by mod. date and descending order, i can do cmnd+shift+B w/out any problem. i'd done this on 3 diff. pt 5.1 system, same result. digi, plz look into it...
thx
Old 03-20-2001, 02:43 PM
Yes, Again Basically I'm on a 9500/200 with a Newertech G3 Mix24 / VinFarm / Samplecell /StoreCase & Atto LVD Dual3D that has been bullet proof for a long time.. as soon as I up'ed to 5.1 Removing or deleating files from the bin.....or removing the new 5.1 Ghosts of files deleated in the finder would quit PT more than half the time....I'm very good with keeping things clean, optimized,checked.....Rebuilt desktop regularly.....I'm an Engineer/composer/Sound Designer and I often combine old sessions, tracks,or only sound files with new projects for common elements....I end up with big bloated Sessions than I then prune of unneccessary files....Lately the only way to do this for me has been to save copy as 5.01 then remove unwanted files in the finder, then skip unfound files on reload....
Old 03-21-2001, 01:03 AM
interesting. I usually sort by source file creation date, with the newest at the bottom. I will try some combinations...when I would rather crash than work. maybe later today.
tom
www.tompaul.com
key command to delete all inserts evan brass Pro Tools 9 1 03-12-2012 04:03 PM
Sound Miner key command to delete files? Postman Post - Surround - Video 7 09-18-2009 05:12 PM
D-Command, delete active groups? Where? rbeggs ICON & C|24 5 02-12-2007 09:07 AM
How to delete a session file? sanantomexican 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-17-2005 08:23 PM
5.1 File Delete Crash Bug TommyT Pro Tools TDM Systems (Mac) 1 03-02-2001 08:38 AM
