Hi
I would like to know if you've noticed differences of performances between a pc that as : 1/ an internal audio HD 2/ an external USB2 Audio HD 3/an external FireWire Audio HD Additional question : Is it better to put the external audio HD in USB2 or to daisy chain the audio HD with the digi002R ? Tks |
In my experience, an internal audio drive will always give better performance and reliability.
For external drives, it is recommended (in the Getting Started Guide) that you use a separate FireWire port for your hard drive and your 002r, but if only one is available, they instruct you to chain the drive first, then the 002r. USB drives are not supported or recommended at all, even though some people have had luck with them. My suggestion, from experience, is to steer clear of them and stick to the recommendations.
tks.
as my computer is a laptop, i have only one HD so i can't have a dedicated audio HD without using an external HD. My latop also as only one firewire ports... So the question is : is it better to use the same internal HD for system and audio or use an external firewire audio HD in daisy chain with my digi 002R ? |
Daisy chained firewire. However, you'd probably see better performance if you purchased one of digi's recommended/approved pcmcia firewire cards.
Cavell Studios |
Digi recommends that you don't record audio to your system drive. So I would have to say go with the fire wire.
I wear the pants. (My wife picks them out) |
![]() Quote:
Wow...talk about some drastic changes to that compato list...thanks, I was unaware.
Cavell Studios |
Yeah, they changed it shortly after Adaptec changed the chipset in the 4300. The first revision of that page only had one card on it!
In my case I had much better performance with a USB2 HD. I bought a dual FW/USB2 so that I could try them out. The FW never worked properly on my Toshiba laptop but the USB2 worked great.
I suggest getting a dual like the Maxtor one-touch. That way you're covered.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
I have the LaCie D2 triple interface external HD (250GB).
It has USB2.0, FW400 and FW800. WHen I had my MacMini, I used USB2.0 interface and it worked as well as FW400. I never tried FW800 since I heard issues about it. Now, I am building a standard Allenstein (still waiting for some parts), and I will check out USB2.0 and FW 400. Asus K8V SE Deluxe has USB2.0 and 2XFW400. I do not know if those 2 FW400s are seperate channels So I was hoping to use USB2.0
Yavuz AKYAZICI Guitar Player, Composer http://cdbaby.com/cd/volcano http://volcanojazz.com http://myspace.com/volcanojazz |
How many audio track on a USB2 drive? | lkingston | Pro Tools M-Powered (Win) | 6 | 06-15-2010 05:03 PM |
Internal Mac audio to PTLE | sylvian | Tips & Tricks | 6 | 11-29-2007 04:36 AM |
External USB2.0 drives as Audio recording drives | injun | Pro Tools TDM Systems (Mac) | 2 | 08-26-2006 08:06 PM |
buzz when internal audio out is used | Paul Southworth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-09-2003 12:43 AM |
Help, routing internal mac audio to 001 | hitp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-30-2003 01:44 AM |
