click track without midi
i want to know how to get a click track in my pro tools without having the stock one go to midi, cause it uses my laptops speakers and not my mbox.
thanks |
Re: click track without midi
You can use the built-in click rtas plugin contained in version 6.x.....or, you can use any virtual synth you have and then route the midi click options to the virtual synth. Sampletank-free has a good sidestick sample/romple.
Cavell Studios |
just get a sample of a high hat or something, set your tempo manually and snap each sample to the grid at the desired note resolution. Thats how I do it, takes the best part of 5 minutes and you can be certain of having an accurate click
That will work too...but sampletank free is free and takes all of 10 seconds...the click plugin is free and takes all of a tenth of a second...and they respond to quick adjustments of tempo...and they don't eat up one of the 32 allotted audio tracks
Cavell Studios |
Bazzle |
Just to clarify, setting the midi click options output to "none" will send you midi click to NOWHERE...not even the mbox. The only way you'll get a click by setting the midi click options output to NONE is by using the plugin called "click" in pro tools le versions 6+.
Cavell Studios |
That's what I meant.Assuming, maybe falsely he was using the click plugin, and it was somehow routed to his onboard Midi which was causing it to play back through his speakers.
Bazzle |
thats what im using.. click.. i rout it to none and it doesnt work.. if its routed to gs wavetable i hear it on my laptop speakers
You have the click plugin inserted on a Mono Aux input.You have click selected in the Midi menu.You have none set in Click options.Do you have a sound loaded in the click plugin?
You may have to navigate from the plugin's import settings menu to the Plugin settings folder and choose a sound.Until I did that there was no factory default.As soon as I showed it the way to the folder it worked correctly.
Bazzle |
in sample tank, i get good clicks.. is there any way to load a sound(i e guitar smack) i recorded into the click plugin , or Sample tank? you know for a click trak of my own key an sound.
Problems With MIDI/Click Track | acidcabin | Windows | 2 | 12-14-2012 02:32 AM |
Click Track and MIDI/Instruments... | joeldorman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-09-2010 10:58 AM |
MIDI sync with PT 7.4 click track | munit54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-04-2009 01:40 AM |
Click track and MIDI all over the place | Grizz1978 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-15-2008 05:58 PM |
MIDI track and click syncing | MrMike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-07-2002 05:11 AM |
