Old 04-21-2004, 11:56 PM
TheLP TheLP is offline
Default Newbie automation question
Now that I don't have my reference guide(Thanks digi!) I need some help. Also, I searched the forums but most of the automation questions were about faders.
Ok I want to send a plug-in so that it sticks to the piece, but every time I try it doesn't work. I have Plug-in automation selected I put it on Auto write(Which maybe the thing, but I also tried auto latch and it didn't work). Anyone know what im doing wrong?
[TheLP]
Old 04-22-2004, 12:31 AM
Roy Howell Roy Howell is offline
Default Re: Newbie automation question
TheLP,
On the plugin itself, click 'auto' and there's a list of things that you can automate on the plugin. Choose/click on the ones you will be actually altering during automation. Then, the plugin will respond during normal automation.
-Roy
rh music
Old 04-22-2004, 12:56 AM
The reference guide is available for download in the Technical Docs section of this web site.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-22-2004, 07:59 AM
Thanks alot roy it works now. And rail what folder do I put the ref guide in to select it from with-in ProTools? Is it possible. Thanks
[TheLP]
Old 04-22-2004, 08:15 AM
Bazzle Bazzle is offline
Find the folder in Digidesign called Documentation and then inside that Protools, put the Reference Guide in there.
Bazzle
Old 04-22-2004, 08:20 AM
I tried that bazz it didn't work, Whenever I click on any of the reference guides in pro tools nothing happens. Only one that works is 'About Pro Tools'
[TheLP]
Old 04-22-2004, 08:25 AM
When I first installed 6.1 it was like that but when I put 6.1.1 it was in the right place.Maybe try 'Repair' installation and make sure the documentation box is checked.
Bazzle
Old 04-22-2004, 08:33 AM
O I found a post by rail and he explained it, you have to put these extra help files somewhere. If I only I knew where lol .
[TheLP]
Old 04-22-2004, 08:37 AM
LP mine are where I said they were and they work fine.Try the Repair thing it won't hurt, maybe you will get lucky.
Bazzle
Old 04-22-2004, 12:39 PM
Read my post in this thread and rename the PDF file to match in the path I specified.
Rail
Platinum Samples
trim automation newbie grendizer Pro Tools TDM Systems (Mac) 4 01-29-2011 08:40 AM
General Venue Automation Question - (Maybe dumb question) TwoPort VENUE Live Sound Systems 5 12-21-2007 03:41 PM
automation newbie Colorblind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2007 05:52 PM
PT Newbie: Multiple Automation Playlists Question ROMI_1 Tips & Tricks 5 12-10-2004 05:34 PM
Newbie question on editing automation data davetron5000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2003 12:20 AM
