Old 01-08-2009, 08:22 PM
soundman6 soundman6 is offline
Default Windows wont recognize MBox
I just bought my first pair of monitors to go with my MBox mini and they respond perfectly to the inputs on it, but for some reason i cant get windows to use them. I went into the sound and audio devices menu and set the Mini as the default playback device, but it won't give me any real sound. The only thing i have managed to get is a very quiet response the the windows program events when i test them. I have already reinstalled protools (7.4) and that didn't help. Any suggestions?
Old 01-08-2009, 11:59 PM
sw rec sw rec is offline
Default Re: Windows wont recognize MBox
More info is definitely in order. What OS, Xp or Vista? If it's XP you can use the MME Helper :
http://www.digidesign.com/index.cfm?...4&itemid=27146
and "opt in" other Windows programs. BUT if it's Vista, there's no wave driver as of yet
and you're out of luck. BTW, even in XP forget Quicktime & I-tunes, there's been a "known incompatibility issues" for years.
Old 01-10-2009, 08:16 PM
The MME helper did not seem to help, but here is a diagnostic of my system.
SiSoftware Sandra
System
Host Name : JON45
User : Jon Smith
Workgroup : BOYACK
Processor
Model : Intel(R) Pentium(R) 4 CPU 3.40GHz
Speed : 3.39GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 2 Unit(s)
Internal Data Cache : 2x 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 lines per sector
L2 On-board Cache : 2x 1MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector
System
System : Dell Inc. Dimension 8400
Mainboard : Dell Inc. 0U7077
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : Dell Inc. A03
Total Memory : 3GB DIMM DDR2
Chipset
Model : Dell Dimension 8400
Front Side Bus Speed : 4x 200MHz (800MHz)
Memory Bus Speed : 4x 133MHz (532MHz)
Memory Module(s)
Memory Module : Samsung M3 78T3253FG0-CD5 256MB DIMM DDR2 PC2-4300U DDR2-534 (4.0-4-4-11 2-15-4-2)
Memory Module : Corsair VS512MB533D2 512MB DIMM DDR2 PC2-4300U DDR2-534 (4.0-4-4-12 2-16-4-2)
Memory Module : Silicon Tech SimpleTechSimple 2GB DIMM DDR2 PC2-5300U DDR2-666 (5.0-5-5-15 3-20-5-3)
Video System
Adapter : NVIDIA GeForce 6800 (256MB DDR, 324MHz/2x598MHz, PCIe 1.00 x16, PS3.0, VS3.0)
Storage Devices
ST3160023AS 160GB (SATA150, 3.5", NCQ, 8MB Cache) : 149GB (C:)
WDC WD4000YR-01PLB0 400GB (USB, 3.5", 7200rpm, 8MB Cache) : 373GB (F:)
HL-DT-ST DVD-ROM GDR8163B (ATA33, DVD+-R, CD-R, 256kB Cache) : 4GB (D:)
PHILIPS DVD+-RW DVD8701 (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
Hard Disk (C:) : 145GB (NTFS) @ ST3160023AS 160GB (SATA150, 3.5", NCQ, 8MB Cache)
Hard Disk (F:) : 373GB (NTFS) @ WDC WD4000YR-01PLB0 400GB (USB, 3.5", 7200rpm, 8MB Cache)
Pro Tools LE (D:) : 4GB (CDFS) @ HL-DT-ST DVD-ROM GDR8163B (ATA33, DVD+-R, CD-R, 256kB Cache)
CD-ROM/DVD (E:) : N/A @ PHILIPS DVD+-RW DVD8701 (ATA33, DVD+-RW, CD-RW, 2MB Cache)
3.5" 1.44MB (A:) : N/A
Peripherals
LPC Hub Controller 1 : Intel 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge
LPC Legacy Controller 1 : SMSC LPC v1
Audio Device : Creative Labs EMU10K2 Audio Chipset (SB Audigy Series)
Serial Port(s) : 2
Parallel Port(s) : 1
Disk Controller : Dell Dimension 8400
USB Controller 1 : Dell Dimension 8400
USB Controller 2 : Dell Dimension 8400
USB Controller 3 : Dell Dimension 8400
USB Controller 4 : Dell Dimension 8400
USB Controller 5 : Dell Dimension 8400
FireWire/1394 Controller 1 : Creative Labs Audigy 2 Firewire Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : EPSON Stylus CX4800 Series (360x360, USB, Colour)
Printer : HP Photosmart C3100 series (600x600, Colour)
Network Services
Network Adapter : Broadcom NetXtreme 57xx Gigabit Controller - Packet Scheduler Miniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Old 01-11-2009, 08:41 AM
Two things...you have to MANUALLY add the programs you want to "Opt in" on the MME helper. AND you can only have one audio source at a time...no "sharing" on this one.
Old 01-11-2009, 08:42 AM
The Weed's Avatar
The Weed The Weed is offline
Do you have the necessary "ins" of the Windows Mixer showing and turned up?
What are the levels set at in Windows Audio Controls?
Where is the Mix/Play knob on the M Box Mini?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-12-2009, 01:50 AM
Good News! The MME helper got Itunes to work. Unfortunately all the music i play sounds choppy, and generally like it is being attacked by an army of robots. Still it is good to hear something come out of it. I have no idea what would cause this, and Itunes is the only program other than protools that i have gotten a response from. I entered in firefox, quicktime, and windows media player into the MME menu, but still have no response. As for the windows audio controls, it refused to recognize the MBOX as a mixer device.
Thanks for the tips guys, your help is appreciated
Old 01-12-2009, 09:35 AM
Unhappy Re: Windows wont recognize MBox
[quote=soundman6;1333824]Good News! The MME helper got Itunes to work. Unfortunately all the music i play sounds choppy, and generally like it is being attacked by an army of robots.
Because there's a "known issue" between I-tunes and Digi that's been known for YEARS but there's no "known" fix for it........
PC wont recognize my Mbox Pro. Please Help. Leonidas33 Pro Tools SE and Essential (Win) 1 04-17-2012 03:35 PM
PowerMac wont Recognize Mbox 2 pfrg999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-01-2011 09:59 PM
Help? protools wont recognize my mbox. jraff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-26-2011 03:15 AM
Pro tools LE 8 wont recognize mbox 2 khammon11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-11-2010 10:07 AM
mac book pro wont recognize mbox 002 devon502 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-30-2006 04:40 AM
