Old 02-26-2010, 11:05 AM
Rhapsody Rhapsody is offline
Default Help! What is a 32-bit Float Mix ?????
I'm working with PTLE 7.4 and I'm sending a mix out which is at 24/44.1 for mastering.The mastering house is asking for a 32-bit float mix (vs. 24 or 16). I know ProTools records internally a 32bit but I never heard of a 32-bit float mix . I normally keep the mixes at 24/44.1 for mastering.
The mastering house says noticed significant improvements in sound quality with 32-bit float mixes.
Does anyone know how to go about doing a 32-bit float mix with PT7.4 LE? Any help on this would be greatly appreicated.......
Thanks in Advance
Old 02-26-2010, 11:11 AM
Top Jimmy's Avatar
Default Re: Help! What is a 32-bit Float Mix ?????
You can't. Pro Tools cannot do 32-bit float files. Your mastering house is full o' crap, especially if this project is ending up at 16/44.1.
James Cadwallader
Old 02-26-2010, 11:46 AM
waltz mastering's Avatar
waltz mastering waltz mastering is offline
It does seem very weird that any respectable mastering house would not be able to take 24 or 16 bit files. Hmmm.
Seriously, Sample rate conversion is one of the things any ME should be able to handle..and asking you to do it is strange.
Tom W
www.waltzmastering.com
Old 02-26-2010, 02:57 PM
The Dougfather The Dougfather is offline
I've heard 32 bit float references to cubase.
At the end of the day if it's in 24/44.1 then thats it, no conversion is going to make it sound better. It is what it is???
If your on the lookout for mastering then check out Tom's site above, i haven't dealt with him personally but at $75 for an e-master is has to be worth a punt.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 02-26-2010, 04:22 PM
Craig F Craig F is offline
Any "Mastering House" that does not know that Pro Tools doesn't do 32 bit files is not anyplace worth going to.
Thank you,
Craig
Old 02-26-2010, 09:39 PM
Bender Bender is offline
32 bit float means the math in the computing not an export file format.
Sonar, Cubase, Magic Samplitude spec that they use 32bit floating point
They are not asking for a 32bit file
They are asking for audio software that uses this math, WHY!
Old 02-27-2010, 09:46 AM
Top Jimmy's Avatar
Sorry to expose the error Bender, but there is such a thing as a 32-bit IEEE float wav file.
Pro Tools LE also uses 32-bit floating point notation, but can neither import nor export 32-bit float files.
James Cadwallader
24 or 32 bit float Bender macOS 26 03-13-2018 06:41 AM
32 Bit Float boogiemotel macOS 76 01-20-2013 09:28 PM
32 Bit Float boogiemotel Pro Tools 10 28 01-09-2013 10:22 AM
new recorders run 24 bit vs 32 bit float rockguitarist1255 Pro Tools 10 1 01-07-2012 10:06 PM
32 bit Float Logichead Pro Tools 10 0 10-22-2011 11:08 AM
