Old 04-10-2003, 09:59 PM
mgbasinski mgbasinski is offline
Default Bug in Digi Core Audio Driver? Driver update coming?
I tested Digi Core Audio driver with Reason 2.0 and also with the Reason 2.5 RC5 Beta release, and neither one worked with the Digi Core Audio drivers. I posted a note to the Reason beta forum/bug collection site to let them know (passing on the info from Digi about mono vs stereo streams).
Today I had the following in an email from Propellerheads tech support:
On Digidesign's website, they have posted the following:
<blockquote><font size="1" face="Verdana, Arial">quote:<hr /><font size="2" face="Verdana, Arial">
"Reason does not work with the CoreAudio driver at this time. This is because Reason only supports stereo streams, and our CoreAudio driver presents mono streams. According to the CoreAudio spec, the application (Reason) should be able to handle either stereo or mono streams. Digidesign has notified Apple and Propellerhead Software regarding this issue, so hopefully there will be an update to Reason that supports mono streams."
<font size="2" face="Verdana, Arial">This applies for Reason 2.0.1 (and earlier Reason versions of Reason). It does not apply for Reason 2.5.
However, very recently a bug was discovered in Digidesign's Core Audio driver which makes it incompatible with Reason 2.5. This bug has been confirmed by Digidesign, they will fix this bug in a driver upgrade.
Best regards,
Propellerhead Tech Support
<hr /></blockquote><font size="2" face="Verdana, Arial">Very interesting. Any comment, Digi? When might we expect to see the core audio driver update?
Mark
iMac G5 2.1Hz /1.5 GB Ram
OS X 10.4.10
MBox/PT LE 7.4
Reason 3.0.4
MOTU 828
Logic Express 8.0.0
Garage Band 4.1
Digi Core Audio Driver nate9 macOS 3 03-23-2013 07:43 AM
Is there an update for Core audio driver for mac 10.6 002 Rack? Timebot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-08-2010 01:56 PM
Installing PT with no digi core audio driver Logic Pro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-07-2009 02:41 AM
Core Audio driver update? pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-25-2003 11:37 PM
Digi ....Core Audio Driver archtop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-30-2003 08:30 AM
