There is a BAR in fullscreen video window again (Windows)
There is a title bar in the full screen video window again (Windows). I had first installed 2019.12, which also had a title bar in the fullscreen video window. So I decided to install 2020.3 which popped up in the newly appeared Avid link app...
Is this a new feature?.. Can this be removed? The title bar also compromises the video resolution and with that adds two more black bars to the sides. Looks like I need to downgrade to good'ol 12.7.1 again, which was a pleasantly stable version, and WITHOUT a bar in the full screen video window. Last edited by mdb; 04-04-2020 at 01:50 AM. |
Re: There is a BAR in fullscreen video window again (Windows)
at least you only get a bar. Mine goes completely black or to garbage. I then have to save and exit by hot keys. As soon as I exit the session, the video goes back to normal though. I was sure they spent the last 4 months testing this very well. I guess not.... I will be uninstalling and going back to 2019.12. At least it was somewhat stable.
and I did try disabling the "enable gpu" option but no difference. so far things that I know cause the video corruption -- bouncing to disk, opening a plugin. So yeah, pretty much anything
Pro Tools 2022.9 UAD Apollo 16 (v10.1) Dell XPS 8940 (i5-11400) Win10 www.studiodrumtracks.com www.doubledogrecording.com |
Ugh... This is sort of depressing.
I was pretty close to upgrading to Ultimate, but I can't deal with a broken video engine.
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
Wow, sorry everybody is having problems, and at the same time, glad I’m not alone. I get the blank black box (sometimes white) and if you even try to move or resize it, you get an “unrecoverable video engine error,” and it gets stuck in a loop until you tell it to stop trying to reinitialize. This is irrespective of what format of video I try to import. But I tried importing video on an old 8.0.5 install, and it works perfectly. What’s the chance we all got a corrupt installer?
Hm.. Sounds like I'm "lucky".
Perhaps I should have mentioned that the bar that I'm talking about is just a Windows title bar. It does not actually go full screen like it did in 12, but rather maximizes the window. I've edited my opening post to clear that up. |
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Same here. Shows title bar (white and big!) on video window. Very annoying. Came with the last update to 2020.3 So now it isn't possible to get 100% full screen.
Avid, please fix! Why is it that with an update you always get unwanted side effects? Why change when it is working properly? The real estate of the Pro Tools title bars in Windows 10 is already rather huge in comparison to MacOs. You get 3 bars on top of each other! With the Mix/Edit windows in retro Windows 7 style....how nice. |
Just updated to 2020.11 to see if it would fix this, but alas, no. It's the worst.
I'm not sure how it works on Windows, but on macos you can replace the video engine with an older version by opening the .app package and simply replacing the Avid Video Engine file with an older one. This solved some video engine issues in the past for me.
Resurecting old thread, but was googling for this problem.
There is this free utility, Borderless Gaming, it's perfect. You can even set it to automatically make video full screen at start up on a monitor of your choice. Just make sure you add Avid Video Engine to favorites from application list. |
Set Pro Tools to open in fullscreen? | GOOOTOOO | Pro Tools 2020 | 2 | 04-03-2020 12:40 PM |
Fullscreen at startup | MusicMadness | Pro Tools 2018 | 4 | 04-11-2018 02:52 AM |
No Video Playback (Black Video window and thumbs) | winkelement | Pro Tools 12 | 13 | 03-17-2016 11:03 AM |
Playing back a 3840x800 Video in Video Window Across Three Screens? | dekstar253 | Post - Surround - Video | 1 | 10-29-2015 06:30 PM |
PT MacOS Fullscreen support | clausiii | Pro Tools 12 | 2 | 08-23-2015 12:15 AM |
