Old 11-21-2013, 03:32 PM
GreenWire GreenWire is offline
Default Pro Tools 10 not seeing MOTU interface after migrating
Hi there. I've recently switched computers, from an older MacPro to a 2009-era one. I'd been using my MOTU 2408mk3 interface without a hitch on the old computer, but after moving to the new one, it doesn't show up as an available interface. All that's in my Hardware list is my iSight camera. I'm up to date on the MOTU drivers, and PT was a fresh download off the Avid site, so I'm out of ideas. Any suggestions?
Thanks.
Old 11-21-2013, 07:35 PM
Chief Technician's Avatar
Question Re: Pro Tools 10 not seeing MOTU interface after migrating
Originally Posted by GreenWire View Post
Any suggestions?
Apple menu-->About This Mac-->More Info...
Now you are in System Profiler. Select FireWire in the left hand pane. Is the MOTU listed in the main pane to the right?
Old 11-21-2013, 07:56 PM
Default Re: Pro Tools 10 not seeing MOTU interface after migrating
No, but it's a PCI card. The 424 card does show up in that field, and it works fine in Digital Performer and with all my system audio.
Old 11-22-2013, 09:48 AM
Is the MOTU interface available for System sounds and sound output (i.e. iTunes, QuickTime, etc.)? Is Pro Tools the only application that cannot access this device?
Old 11-22-2013, 12:12 PM
Yup, working fine with everything else except Pro Tools.
Old 11-22-2013, 06:29 PM
Hold down the 'n' key while starting PT and you should be able to select the MOTU. Are you maybe using an OSX version the MOTU doesn't fully support?
Jack
QAPLA!
Old 11-22-2013, 08:31 PM
That did the trick, held the n and managed to select the interface. Thanks very much for your help, both of you!
Old 11-23-2013, 05:08 AM
No problem - glad that worked. It often cures a multitude of sins when nothing else seems to work.
Jack
QAPLA!
Pro tools aggregate with FWx and Motu interface Eyevanovich VENUE Live Sound Systems 2 01-13-2014 02:55 AM
Migrating to iMac, and want to use my 96 interface Oli P Pro Tools TDM Systems (Mac) 17 02-07-2013 01:21 AM
Migrating Pro Tools sessions from Windows to Mac RandB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-09-2008 11:21 AM
Pro Tools Le with MOTU 896 interface? blsdmf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-15-2007 12:17 AM
Pro Tools M-Powered with Motu Interface?? Haraldur Levi Pro Tools M-Powered (Mac) 2 04-20-2006 09:00 AM
