Has anyone used this setup? How has it worked?
It can't be done... PTLE will only work with Digi interfaces. PT M-Powered will only work with M-Audio gear. No exceptions.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
I suppose you could use the 896 in stand-alone mode for the mic pre's and run its ADAT output into a Digi 002r interface, but this would be kind of redundant unless you already have an 896 sitting around. But Digi software will not run without Digi hardware attached. If you want to use the 896 however, you can use its included Audiodesk software or almost any other software you prefer except for Pro Tools. The 896 has an advantage of having low-latency Cue Mix monitoring as well.
Bob
Save early and often! (or once a day whether you need to or not...) |
I have imported tracks recorded using MOTU hardware on a different computer. But as stated, the LE software needs the PT hardware.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
hi, quick guestion.
is it possible to use the 896 or any other non-digidesign interfaces if you already have digi gear? i have an mbox 1, but am looking to get more i/o's. the problem with the 002 is it only has the 4 preamps and i need more. thanks in advance. |
Need more preamps, try the Studio Projects VTB1... best bang for the buck... I get them for around $80 per pre from Full Compass, and knock the socks of the Digi pre's. Make a hell of a Tube Bass DI as well. They also have the rackmount to put two side by side. Anyway... a little random but oh well.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
You can only i/o through the Digi gear. You could use other gear, as long as it gets or send its audio via the Digi gear.
Sam Ejnes Mix Technician, Freelance Sound Editor/Re-recording Mixer samejnes.com | IMDb | Analog Jitter rMacBook Pro 2.2 gHz Core i7, 10.10.3 16 GB RAM MOTU 828mkII, PT 12.1 HD Axiom 61, 2xArtist Mix |
Pro tools aggregate with FWx and Motu interface | Eyevanovich | VENUE Live Sound Systems | 2 | 01-13-2014 02:55 AM |
Pro Tools 10 not seeing MOTU interface after migrating | GreenWire | Pro Tools 10 | 7 | 11-23-2013 05:08 AM |
Motu Interface | RoadTech22 | General Discussion | 3 | 09-04-2012 05:15 PM |
Anybody using a MOTU interface with PT 10? | albee1952 | Pro Tools 10 | 40 | 08-22-2012 09:08 AM |
Pro Tools M-Powered with Motu Interface?? | Haraldur Levi | Pro Tools M-Powered (Mac) | 2 | 04-20-2006 09:00 AM |
