Old 01-06-2021, 03:37 AM
Default Re: Please recommend an external SSD drive for me
Originally Posted by Emi View Post
Darryl, the doubt I have about disc cache: if o allocate only 1gb and the session has more, let’s say 3-4 Gb, does the disc cache buffers audio along the way or it only caches 1 gb and the rest doesn’t? If it caches as the session is being played can this produce errors?
Thanks
Not so much errors like 9173/whatever but pops and crackles IF you're using a spinner for your sessions. AND at the same time running with low buffer settings. I ran into just such a situation a couple of months back. But with an internal ssd for sessions there shouldn't be a problem.
Old 01-06-2021, 04:55 AM
Thanks
My understanding is it tries to do something sane but you cannot get blood out of a stone. Memory is cheap if you can add it... fast PCIe/NVMe disk always helps and both together should also interact well, e.g. IIRC it looked like Pro Tools uses fairly efficient asynchronous IO to write modified content out of the disk cache, the sort of stuff that plays well on fast SSD.
Understanding what is going on with overall memory is a little complex on modern demand paged operating systems like OS X/macOS and Windows, and that is made even more complex with black magic like memory compression. It may be possible to increase disk cache beyond initial impressions and have it work OK, or maybe not... may be worth testing, but obviously not great to be running on the edge... and if using lots of VI samples and you have a fast SSD then maybe streaming samples is an option vs caching. Oh and make sure memory pigs like Google Chrome are just not running.
Old 01-06-2021, 07:44 AM
Emi's Avatar
Emi Emi is offline
Yeah, I remember when you had that problem. Told you it was the spinner.
I actually don’t have any problem with errors with ssd and the disk cache is at normal.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 01-06-2021, 07:48 AM
Emi's Avatar
Emi Emi is offline
Thanks Darryl, I had to double read, and still have doubts about it. I understand is hard to explain what it is actually doing.
I’m running disk cache at normal (so, no buffering) without any issues with ssd’s
Old 01-06-2021, 10:57 AM
The spinner is NOT the problem. Been through that already.
Old 01-06-2021, 11:31 AM
Emi's Avatar
Emi Emi is offline
What was the problem? Have you discover it?
Old 01-06-2021, 12:15 PM
Like I said in the original thread it's a combo of low buffers and low cache setting.
Old 01-06-2021, 08:33 PM
paul_g's Avatar
paul_g paul_g is offline
My problem existed between the keyboard and chair!
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 01-07-2021, 12:06 AM
Emi's Avatar
Emi Emi is offline
Lol
Recommend external hard drive jasonsmith General Discussion 28 10-16-2013 09:44 AM
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
Recommend Firewire external drive for iMac jiagap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 02-03-2010 08:12 AM
recommend external hard drive?? robotman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-23-2009 07:30 PM
please recommend me an external eSATA drive sterndrup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-08-2008 11:08 AM
