Media Station / AES Speed Issues
7.1cs5, MS 1.8.2, Quad Core G5 w/ HD2. Sync I/O, 192.
Ingesting into media station via AES/ebu causes a second or so speed mismatch - the audio is faster then it should be. After a second, there a very faint audio drop out before it gets to the correct speed. This is not noticable when ingesting, only when the footage is played back. Ingest deck is a DigiBeta, DVW500. I believe Media Station is set to have all incoming audio at 48K. If I injest with the same setup in PT, I have no issues whatsoever. Thoughts? Thanks all!
.: michael kammes mpse .: post audio .: applications editor / workflow consultant .: michaelkammes.com .: lucidsound.com |
Re: Media Station / AES Speed Issues
In the MediaStation Capture window, is the input set to 'AES/EBU (Encl)'?
What happens if you record from a different AES/EBU source - does the same problem occur? What happens if you turn off the Video and TC record in the Capture window and just record audio? |
Thanks for the reply.
1) [ENCL] is NOT selected. Just AES/EBU. 2) Other AES sources yield the same result. (BTW, in your SYNC I/O settings, within PT there are 2 entries for the DVW500. Reason being...? 3) That one I have not tried, and I don't know when I'll be onsite again. Wish I had more info!
Media Station PT 2.7 is $495 ?! | PilPro | Post - Surround - Video | 7 | 12-16-2007 11:29 PM |
7.3 and Media Station | Lane McGiboney | Post - Surround - Video | 4 | 08-06-2007 06:41 AM |
Media Station | shockwave2501 | Pro Tools TDM Systems (Mac) | 2 | 05-03-2006 10:03 AM |
Media Station | shockwave2501 | Pro Tools TDM Systems (Mac) | 0 | 05-02-2006 02:21 PM |
Media Station | N-G-NEER | Post - Surround - Video | 11 | 01-03-2006 12:00 PM |
