\"Timeline\" and \"Session\" lights in edit window
I've searched the manual, but have not found out what the "timeline" and "session" indicators mean. They are located in the edit window above the tracks on the right-hand side. The lights are green or red.
Thanks- PC
I don't know karate but I know KA-RAZY! |
Re: \"Timeline\" and \"Session\" lights in edit window
bmp
If the timeline LED is green, it means you don't have any offline regions on any playlists. If it's red, you do
If the session LED is green, it means there are no offline regions in the session. If it's red, you do. |
Sorry, but could you go deeper into what you mean by offline regions? Does this mean out of reach (ie: deleted)? Moved?
Luckily, I'm just curious, nothing seems to be going wrong.. Thanks- PC
Offline regions are regions whose actual audio file can't be found for one reason or another. Typically, the session will prompt you when you open it that it can't find something. If it's been deleted or is otherwise lost, any regions referencing the audio file(s) that are missing will become offline. Those regions will then appear italicized on the track and the regions list. I hope that helps.
PT 8 Edit window timeline problem | porkipine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-05-2010 07:56 PM |
PT8 edit window timeline jerky | Dazly | Post - Surround - Video | 10 | 10-23-2009 05:03 PM |
edit window doesnt follow timeline ? | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-14-2009 06:42 PM |
Question : Timeline and Session indicator lights | Muxlow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-30-2003 07:32 AM |
So, what are the green/red timeline and session lights in the Pro Tools 6 toolbar? | uno1234 | Pro Tools TDM Systems (Mac) | 1 | 04-06-2003 04:43 PM |
