Old 05-04-2011, 03:53 PM
lbow lbow is offline
Default MC Mix disconnects after 20 sec
Just installed Pro Tools 9.0.2 (HD) and tried to set up an MC Mix that I just got. After 20 seconds the MC Mix does no longer interact with Pro Tools, scribble lights go dim. When I deactivate Eucon in Ethernet controllers, then re-activate it again, the same thing occurs. It works for 20 seconds, then disconnects itself. I am running Eucon 2.5.7, after updating firmware on the MC Mix from 1.41 to 1.44 nothing changed. Perhaps I am missing something. The MC Mix worked well on a Logic system. Does anybody have similar issues? Thanks very much!
Old 05-07-2011, 04:49 AM
Eddie Eagle Eddie Eagle is offline
Default Re: MC Mix disconnects after 20 sec
Check your firewall settings. Turn the firewall off and try again.
Hope that helps,
Eddie
Old 06-09-2011, 02:13 AM
Eddie, thanks for your suggestion, but the firewall was not on. Everything works fine if I use it with Logic, so I suppose that the problem is somewhere between Eucon and Pro Tools....
ilok disconnects while using PT 10 teketuco General Discussion 2 08-26-2013 06:28 PM
Web Browser Disconnects Interface - Help! CliffT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-01-2010 11:46 AM
mbox 2 disconnects dishdive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-26-2006 05:01 PM
002 Rack Disconnects GJH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-01-2005 02:18 PM
002r disconnects? barznbeats1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 07-18-2005 11:13 PM
