Old 07-11-2005, 10:57 PM
barznbeats1 barznbeats1 is offline
Default 002r disconnects?
About 20 minutes into a session it seems my 002r disconnects or something. I get a message saying that protools cannot commubicate with HUI. Also, anything I have connected via the firewire port is diconnected ie. external hard drive. Has anyone else had this problem? The 002r doesn't shut offthough. I usually have to turn the 002r off then on again for the midi and firewire to work again. What could this be?
Old 07-11-2005, 11:02 PM
Matt Whritenour Matt Whritenour is offline
Default Re: 002r disconnects?
bad power harness
www.klarityrecordingstudios.com
Old 07-11-2005, 11:08 PM
Are you sure? I mean the 002r isn't losing power or powering off. So how do I get a new harness? Have you had this problem?
Old 07-17-2005, 08:31 PM
dsmuv dsmuv is offline
recently Ive had the same problem also. after a while it seems like my interface will disconnect from the computer. When this happens the only light thats shows is the mute button. Then it will start clicking like its trying to reconnect then reconnect then disconnect again. I used to be able to turn of the interface and turn it back on but not it has gotten worse. As of right now I cannot use my interface....I dont know if it can be a bad power harness because the interface seems to always be "on" even though its not communicating with my computer......CAN ANYBODY HELP PLEASE????
Old 07-17-2005, 08:40 PM
scottedog scottedog is offline
Contact Digi and get another power harness.
Scott.
ScottedogStudios on ReverbNation
Old 07-17-2005, 08:48 PM
Do you have a ballpark figure on how much the power harness would cost?
Old 07-17-2005, 08:51 PM
I'd be pretty certain it would be free.
Scott.
Old 07-17-2005, 09:05 PM
cool thank.... bye the way I sorry if this sounds ignorant but what does the power harness look like and what is its significance to the 002 rack?
Old 07-18-2005, 03:03 AM
Mocata Mocata is offline
Does your OO2R click when it disconnects?
What you are describing is almost certainly down to a faulty power harness.
My 002R had exactly the same problem.
Contact Digidesign and they should send you a new one.
The power harness is a collection of cables that transfers electricity from the 002Rs internal power supply unit (PSU) to it's system board. Fitting it is simple and Digidesign will send you explicit instructions on how to complete the task with your new harness.
Best of luck,
M
Old 07-18-2005, 03:53 AM
Joe Evans Joe Evans is offline
Yeah, the clicking is a dead giveaway. Bad power harness. Digi will make good on this though. In the mean time you can try reseating the power harness cable. Some people have had good results with this procedure.
--joe
ilok disconnects while using PT 10 teketuco General Discussion 2 08-26-2013 05:28 PM
MC Mix disconnects after 20 sec lbow Artist Series 2 06-09-2011 01:13 AM
digi 002r crackles and disconnects studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 09-07-2007 12:39 PM
mbox 2 disconnects dishdive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-26-2006 04:01 PM
002r disconnects all the time !!! Bossi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-27-2004 12:13 PM
