Old 01-16-2018, 07:50 AM
Sir Hannes Sir Hannes is offline
Default "Reset" of a track's inserts and send slots? (solved)
As the title says: I am missing a one menu -> one click command to clear a track's slots completely. Anyone knows?
Old 01-16-2018, 09:41 AM
Drew Mazurek's Avatar
Default Re: "Reset" of a track's inserts and send slots?
It doesn't exist AFAIK.
Post it here.
http://protools.ideascale.com
Workaround: use ISD to bring in Inserts and Sends from a known blank track in your template.
www.drewmazurek.com
Old 01-16-2018, 10:50 AM
Carl Kolchak Carl Kolchak is offline
I'm missing something here I guess :
It is only one click to clear a slot (click mouse button on side of insert slot, select "no insert", and release mouse button).
You can also select a bunch of tracks, hold down Alt + Shift and remove the insert, to clear it from the corresponding slot on all selected tracks.
Or just hold the Alt key, whilst removing the insert, to clear that slot across all visible tracks in the session.
Edit :
Ah, I missed the pluralisation.
You want to clear ALL inserts & and sends at once.
Quickest way is to duplicate the track, but uncheck "inserts & sends" from the things to copy.
Old 01-16-2018, 10:54 AM
The OP means all 10 Inserts and all 10 Sends on a single track.
www.drewmazurek.com
Old 01-16-2018, 10:56 AM
Yeah, I just got that whilst you were typing, and whilst I was editing my post.
Old 01-17-2018, 01:30 AM
Hey Carl, you posted a great work around. Thank you
Old 01-17-2018, 08:12 AM
Cool, glad it helped.
Old 01-17-2018, 08:57 AM
You also have the option to insert a new empty track and just cut/paste the audio to it(and delete the original) I agree that it would be a handy feature.
Old 01-17-2018, 09:19 AM
Then you loose some data. Also I am lazy and don't want to write the track name completely from beginning
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
offline bounce from Send or Track outputs - track "freeze feature" OliverH Pro Tools 11 20 05-25-2014 04:45 PM
Why send tracks to hardware outputs instead of "Master" track/bus? gopher Getting Started 11 01-03-2014 12:12 PM
More than 10 (A-J) Send "Slots" Possible in PT 8.1 ? LukeFromBerlin Pro Tools TDM Systems (Mac) 8 02-17-2012 03:11 AM
PT 6 breaks S/PDIF "out" and "inserts" on I/O setup wcody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-04-2003 05:14 PM
