Old 04-17-2013, 12:53 PM
leftalive leftalive is offline
Default Does "Automatically Copy Files on Import" work with Import Audio command?
I seem to remember this working flawlessly in v8, but now on 10.3.4 it seems that the Automatically Copy Files on Import preference doesn't have any effect on the Import Audio command (command+shift+I). It defaults to "add" every time, and I have to manually select "copy", where as in v8 I could just hit the return key every time I wanted to import (and copy) a file.
Does it not work this way anymore? Is the preference only for drag and drop now? God, I hope not...
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 04-17-2013, 07:06 PM
Arrow Re: Does "Automatically Copy Files on Import" work with Import Audio command?
Correct.
It does not work the same way it did in v8.
Yes. Search ideascale.protools.com to see if anyone else has logged this, and if not, log it as a bug.
Old 04-17-2013, 07:59 PM
Default Re: Does "Automatically Copy Files on Import" work with Import Audio command?
I think this is logged as a bug. Now, every time I need to import any audio, I drop it in the session folder and import from there(unless its an empty session, where I will actually drop the audio into the Audio Files folder and import from there). Small PITA, but I hate the missing audio files dance
Old 04-17-2013, 09:35 PM
Grrr.... That's what I was afraid of. For what it's worth, I occasionally have a problem auditioning files from the "clips to import" window as well, although that one seems intermittent, so who knows. I'll take this over to ideascale. Thanks guys.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
Pro Tools 12.4
A loaf of bread
A stick of butter
Import files to "Audio" automatically Herokazz Windows 2 08-29-2012 12:52 PM
"Could not complete the import audio command because DAE error 35 was encountered..." Sean_tiburon macOS 1 02-29-2012 07:03 AM
Automatically copy files on Import not working? Nathan W. Pro Tools TDM Systems (Mac) 1 01-07-2010 10:21 AM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
Automatically copy files on Import (preference) jimlongo Pro Tools TDM Systems (Mac) 0 03-10-2003 02:40 PM
