Old 03-14-2008, 04:03 PM
bspro bspro is offline
Default Bit Rate/Sample Rate problem? The chipmunks?
I've just raw recorded 12 tracks into a 001 with 2 Digimax Lts. I then took the files and opened them on my MBox Mini only to hear that it is in time and in tune with itself, but is higher pitched than reality. What has caused this? I assume it is that something with the bit depth or sample rate not lining up...what do I do to correct this?
Old 03-15-2008, 07:35 AM
Default Re: Bit Rate/Sample Rate problem? The chipmunks?
You must have had a Digimax clock set to 44.1K while your session was at 48K(so everything was actually recorded at 44.1). Try importing the audio(consolidate all the files first) into a new session at 44.1K and DO NOT convert on import. Or search the DUC for Doc's cool converter program(sorry I can't remember what its called). Maybe sift thru the older posts.
Old 03-17-2008, 05:40 PM
Thanks! That was exactly the problem...
48K Sample Rate Problem grayter1 Windows 11 02-08-2015 01:07 PM
Help: Sample rate problem crazytracy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-04-2008 08:19 AM
sample rate problem. Help! Ryan Butler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-07-2007 11:23 AM
sample rate problem John Rose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-12-2006 03:06 PM
Sample rate problem sean shannon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-27-2005 08:07 PM
