Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 04-08-2016, 06:12 AM
johnbonesdoe johnbonesdoe is offline
Default iLok says "Software component unavailable"
Ilok says Software component unavailable. I can't use anything on my Ilok including PT12 because of this. Frustrated.
Old 04-08-2016, 01:45 PM
JakeF JakeF is offline
Default Re: iLok says "Software component unavailable"
I've gotten this before when I have something else open (YouTube, Media Player, etc.) that has control of my sound card and is preventing ProTools from taking it over. Close any programs that may be holding your sound card hostage and try again.
Old 04-08-2016, 04:15 PM
amagras amagras is offline
Are you on Windows? Try this:
To check for this problem*go to Administrative Tools/Services/ and see if "Pace License Services"*status is *"running".
If not running then that is the problem.
The quick fix is to double click or right click and select Properties then change "Startup Type" from "Automatic" to "Automatic (Delayed Startup)". This causes the Pace service to wait a while before running.
Taken from the cakewalk forums
http://forum.cakewalk.com/m/tm.aspx?m=3280463&p=1
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-21-2016, 04:29 PM
Filmusic Filmusic is offline
Hi - I'm having the same problem - tried it changing to to delay - still zero luck - very odd
Old 05-21-2016, 04:38 PM
Did you try just starting it? I think there's an option for that in the same menu.
amagrasmusic.com
Old 05-21-2016, 05:12 PM
Top Jimmy's Avatar
Or how about just rebooting the PC? This happens on my PC after it's been left on for a few days.
James Cadwallader
Old 05-21-2016, 06:57 PM
Yes, the PC still needs to be rebooted for that to work, although in my personal case what works is to change it to delayed, reboot, then changing it back to regular start and reboot again. Once I ended up creating a direct access in my desktop.
amagrasmusic.com
Old 05-22-2016, 01:52 PM
Hi - I spoke too soon - your suggestion has me up-and-running!!
thanks!!
Cheers
S
Old 05-22-2016, 03:17 PM
sw rec sw rec is online now
Now, go into device manager and disable USB power management.
Old 05-23-2016, 10:20 AM
Thanks - will do!
Cheers
S
"Required Software Extensions are Missing" error after getting New iLok jschmidtiii macOS 0 03-28-2016 08:08 PM
"Factory Promo UB" - "Eventide" - iLok license - What plug-in is this? Intini Pro Tools TDM Systems (Mac) 7 08-31-2012 08:27 PM
After installing Pro Tools 10.2, some "LE" plug-ins are unavailable theaudioeditor Windows 23 06-04-2012 04:25 PM
Pro Tools 10.0.1 on OS X Lion, "unrecognized component" initialization failure mscr macOS 1 03-02-2012 02:22 PM
Eleven Rack ERXP-"Unavailable" moog4all General Discussion 1 03-23-2011 07:48 PM
