Old 03-04-2009, 09:05 AM
michael c michael c is offline
Default Strange Master Fader Issue
We are using PT 8 w/ last years Mac Pro 8 core running an HD3 system. We started experiencing a major problem with a Master Fader.
The right side of the Master Fader won't pass audio. We buss all our tracks through an aux 1st so we can print final mix stems within PT. (We have been doing this for several years with no issues.) That aux is passing audio fine but the Master Fader is only passing the left side audio. This has also happened a few times when we send audio out an I/O (5/6) to go to some analog processing gear and then back into PT.
It finally works correctly if we instantiate a plug-in on the Master Fader. This seems to 'clear out' something?
We've trashed the usual DAE pref, etc. and that hasn't fixed the issue. We ran DigiTest and the cards are all fine. Our 192 passes audio correctly.
Any thoughts?
Thank you.
Old 03-04-2009, 09:47 AM
DrFord's Avatar
DrFord DrFord is offline
Default Re: Strange Master Fader Issue
Sounds like a re-install, and make sure you are using the newest version of the "stereo Mixer, stereo dithered mixer, surround mixer and surround dithered mixer."
If you upgraded without a complete uninstall you may be using the 7.4 mixer plug ins. That could be causing it... maybe.
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 03-04-2009, 10:03 AM
myke2242's Avatar
myke2242 myke2242 is offline
I have a similar issue where if i leave my system idle i cant pass audio through optical SPDIF into PT. My solution is to deactivate and re-activated the i/o on the master or Aux and everything works fine.
PT8.0.0CS2 HD2, G5
Old 03-04-2009, 02:44 PM
We did uninstall before we upgraded. Things have worked fine since last December till now. We are going to do an uninstall / reinstall and see if that fixes it.
RT Sac-2k master fader issue midKnight Pro Tools M-Powered (Win) 1 01-08-2010 01:10 PM
strange... master fader stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-02-2009 12:15 AM
ADC and Master Fader Issue wyman Pro Tools TDM Systems (Mac) 21 01-21-2008 01:28 PM
Weird master fader issue jrmintz Pro Tools TDM Systems (Mac) 5 05-29-2007 09:20 AM
Strange 5.1 Master Fader Behavior When Bnc to Disk kcupper Post - Surround - Video 3 03-02-2006 07:10 PM
