Old 05-19-2011, 04:12 PM
YellowDissident YellowDissident is offline
Default Eq Sc 48 mains
Last night I wanted to eq the mains , St L different from st R. I tried different ways but I didn´t get any solution (Tried to use 2 graphic eqs unlinked, but it doesn´t work).Anybody knows how to do this (eq each side from the PA with different parameters)
Thanks
Old 05-19-2011, 04:44 PM
mariojorgeandrade mariojorgeandrade is offline
Default Re: Eq Sc 48 mains
The mains graphic EQs are always linked.
Maybe you should try to accomplish this
(Equalizing the two sides differently to
compensate differences in system and/or
room), outside of the console.
If it's not possible, make your PA outs
from two mono matrixes and use one
graphic EQ in each one, that will work.
Regards,
MJ
Old 05-21-2011, 06:57 PM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
I do all EQ'ing of the mains through our Galileo 616 processor; but the matrix idea would definitely work...that is, if you have two matrices to spare. I would proceed this way with caution tho.
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Output to Mains On?off? FreeBlues Eleven Rack 4 05-02-2013 04:51 AM
Cue on Mains to Matrix J2sound VENUE Live Sound Systems 3 04-17-2012 11:47 AM
Monitor mains on 002 c1jv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2006 09:45 AM
CPU noise through AC mains skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-26-2004 06:35 AM
Mains Hum phamtec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-23-2001 12:58 AM
