2 technical Q\'s
I know a little on this topics but I'm posting real quick and need your input:
1- What exactly are anti-aliasing filters (I have an idea) 2- LE related, What is the "degree of thining" stated on the setup/preference menu in pro tools le.Thanx. [img]images/icons/smile.gif[/img]
Take Care, Gabriel. |
Re: 2 technical Q\'s
http://www4.tomshardware.com/graphic...force2-08.html |
Thinning is an extrapolation of the minute edit points you create when writing automation; think of it as smoothing combined with clearing out unnecessary automation data.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Stone Knife:
Thinning is an extrapolation of the minute edit points you create when writing automation; think of it as smoothing combined with clearing out unnecessary automation data.<HR></BLOCKQUOTE> mmm-k, I sort of get this and thanks Stone, but can someone state in simple english (is not my primary language) what this does to my audio if I set the thinning to none or maybe all the way up. And thanks again Stone and Socata. [img]images/icons/grin.gif[/img]
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by gabriel_p:
mmm-k, I sort of get this and thanks Stone, but can someone state in simple english (is not my primary language) what this does to my audio if I set the thinning to none or maybe all the way up. And thanks again Stone and Socata. [img]images/icons/grin.gif[/img]<HR></BLOCKQUOTE> thinning effects the automation data only, not the actual audio. ~matt |
gabriel_p,
Hi. Thinning does exactly what the word implies. If you do a fader automation by hand, PTLE writes a lot of data to disk showign exactly how you moved the fader. You get maybe 100 automation data points. Now maybe you only need a few, so thinning helps get rid of some of the data along the way. That's all. You can also 'thin' by hand. Just select the pencil, and then push the Alt key. You'll see the pencil invert and now you're erasing. You can erace you automation data points this way. Cheers, Mark |
HI Gabriel
Try this link these guys are experts. The anti alising info is in the pdf on p 7 of 12 filters right hand corner THE ARTICLE IS EXCELENT HERE IT IS http://www.apogeedigital.com/products/prod_uv22.html The File is called Apogee Guide to Digital Audio The adobe reader came with digi-le SDA BAE USA |
Could someone give me a bit of technical help? | Snowblind | Pro Tools M-Powered (Win) | 2 | 12-28-2010 06:50 AM |
Why am I not getting any help with Technical Support??? | mr rhys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-09-2010 07:30 AM |
Need some technical help... | TAMA | Pro Tools M-Powered (Win) | 0 | 03-12-2010 06:50 PM |
Technical set up help! | jiagap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-07-2005 07:05 AM |
Technical Support | digiplex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 12-08-2004 01:27 PM |
