Old 03-24-2007, 06:11 PM
iamnightfall iamnightfall is offline
Default computer noise through monitors???
I've had this problem for awhile now, and its so irritating. I have my G5's audio output running into my 002 rack, the outputs then running into my presonus central station, out to my powered monitors. I've taken the central station out of the signal path, but I still hear high pitched beeping, static, all kinds of noise coming out of my monitors, when the audio from the computer is "alt source to monitor". Any help or someone with same problem??
thanks
Old 03-24-2007, 06:56 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: computer noise through monitors???
That input is unbalanced and subject to interference from all sorts of electronic noise. Re-rout the cables. What are you monitoring on that input???
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Computer noise in monitors ron-e-g General Discussion 4 06-16-2013 06:55 PM
2 computer monitors? dadio2002 General Discussion 2 02-01-2005 09:56 PM
What are you using for computer monitors? SKI 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 08-01-2003 06:48 AM
When Two Computer Monitors Are Just Not Enough! The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 10-12-2002 09:51 AM
When Two Computer Monitors Are Just Not Enough! The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-13-2002 07:02 PM
