Access privileges
A freind of mine had a couple of sessions done on a pc. He gives them to me to mix. the last two sessions i tried to mix would give me the access privileges denied message whenever I tried to do anything. I am sure there is somethiing he did. Since all previous sessions are still working fine. Any Ideas? I will post over in the windows forum also.
Re: Access privileges
With PT closed, navigate to the folder that contains the audio and fade folders and the PT session file. Select the folder or the PT sesh file and audio and fade folders and hold down apple and hit i (get info command) make sure under ownership and permissons that you have read and write selected also unlock the folders by clicking the padlock icon. next make sure that under 'details' ALL options are set to read and write, then hit apply to enclosed items. this should solve your problem. let us know how you get on. regards
Dual 1.8 G5 (1st Gen) 10.3.4 4 GB RAM 2 x Glyph GT050 Pro Tools 6.4 cs9 HD 1 & 96 i/o Waves Gold 867 Powerbook Pro Tools 6.4 & MBox 10.3.4 |
...do not have appropriate access privileges | ifix | macOS | 13 | 03-20-2017 12:30 PM |
Appropriate Access Privileges | Gunnell | Pro Tools M-Powered (Mac) | 3 | 05-13-2015 08:30 PM |
"Necessary access privileges"?? WTF???? | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 05-22-2012 06:25 AM |
Access Privileges | Chris King | Pro Tools TDM Systems (Mac) | 1 | 05-14-2005 07:42 PM |
"you do not have necessary access privileges " | stickleback | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-10-2004 09:29 PM |
