Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 02-24-2018, 12:06 PM
djpbarry djpbarry is offline
Default Latest Driver (1.0.13) for Pro Tools | Quartet doesn't work on Windows 10
I've been having a driver-related issue for a while now with my Quartet on Windows 10.
If I use an old driver (1.0.10), the IO Control Panel installs correctly and seems to run fine (aside from the known issues with that driver).
However, if I upgrade to the most recent driver (1.0.13), the control panel doesn't appear when I attempt to launch it - I just get an empty window:
https://www.dropbox.com/s/ao0qsilnen...pture.PNG?dl=0
Anyone else encountered this problem? I tried to contact Apogee, but they weren't much help - they've decided the Quartet is an Avid product.
Old 02-24-2018, 02:17 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Latest Driver (1.0.13) for Pro Tools | Quartet doesn't work on Windows 10
If the Quartet is a black Avid branded version, then yes its an Avid issue.
Call Avid for support.
IMDB
Old 04-14-2018, 11:16 AM
So, I've had a lengthy email exchange with Avid Customer Care and, to be honest, they've been pretty useless.
I'm no closer to getting this issue resolved. They seem pretty mystified that it works with the latest driver on a Mac, but not on Windows 10.
Anyone else had any issues with the Quartet on Windows 10?
Old 12-20-2019, 01:07 PM
Lightzy Lightzy is offline
I've had many issues.
The reply I got from avid support is to not use windows10 or use an older version and that 'there is no timeline for driver release for newer windows10 versions'. It's like, "whatever yeah, you bought it now deal with it"
I'm not even joking.
PT8 doesn't recognize Eleven Rack after installing latest driver [SOLVED] needled39 Windows 3 09-07-2017 09:49 AM
10.3.2 Mac downloader doesn't work with latest version of Java nedorama macOS 3 10-21-2012 06:33 AM
low latency monitoring doesn't work on 002r latest drivers jntracks Windows 26 03-31-2011 11:23 PM
Latest 003R Driver for PT 9 on Windows 7? lowlights Pro Tools 9 1 11-19-2010 08:54 AM
Latest iTunes (4.9) doesn't work if you have PT?!? vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-30-2005 08:54 PM
