Scale an automation lane?
I would like to make a selection on an automation lane, Pan for instance, and keep the written automation but scale it by 50%.
Say I receive a post mix and the front back automation is too aggressive on a particular track. I'd like to select the front back pan automation lane and hold a modifier key and drag mouse down to scale position of the break points. Keeping the intent but decreasing the range of the movement. It this possible now? Or do I need to go to IdeaScale? |
Re: Scale an automation lane?
cheers john
You can use the All group, then reveal the automation lanes (easiest with Cntrl-command, left/right arrows). Go to just after the session end, and pull down all the automation using the Trim tool. On PTHD, just use Read + Trim and coalesce the changes to the tracks.
What I'd like is something like the clip gain up down by .5dB increments. there is a keyboard shortcut for that. Control+Shift + up or down arrow. I'd like it if this same key command worked for whatever automation lane is showing. |
Been searching around for this.. Can't believe either I can't find it, or it doesn't exist. Working on a long show that was cut in Premier with a LOT of volume automation exported to me in the OMF on the music track. All I want to do is scale it to make the moves less drastic. i.e. 'compress/expand automation points by 20%' or ' raise all points lower than xx dB up by 20%'. OR..even better, a Horizontal Selection tool that will allow you to select all automation points above/below the line, then, once selected, lets you just grab and raise/lower ALL the points at the same time.
Is there really no way to do this???? Here's a screen shot of a real world example. I just want to raise all the 'bottom' automation points up to decrease the range of these music spikes that happen in-between the VO spots.
dg Last edited by DaveGross; 10-30-2017 at 09:03 PM. Reason: clarification added |
If there's a way, I'd like to know too.
cheers john
For the shows I mix I convert volume automation to clip gain, then I use the automation lanes to scale sections. You need HD to do this. I'm used to Digital Performer where I can just highlight a section of automation and add or subtract volume. I'd like to see the same editing that's in the clip gain available in the automation lanes too
ideascale it !!!
And hopefully in the next 5 yrs or so....
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Alt+Shift+Automation-Lane-Change | joachim | Tips & Tricks | 0 | 09-14-2014 09:05 AM |
Volume Trim lane vs Automation | Cliffy_Boy | Pro Tools HDX & HD Native Systems (Mac) | 12 | 03-06-2013 03:19 PM |
No Send Pan automation lane on 9.0.3? | Craig F | macOS | 1 | 04-21-2012 12:12 PM |
automation bug in bypass lane | Postman | Post - Surround - Video | 8 | 01-04-2012 06:20 AM |
Automation lane size not remembered | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-07-2010 09:26 AM |
