Old 04-27-2013, 11:09 AM
larsongs larsongs is offline
Default I/O Settings have changed-No sound?????
This Pro Tools is so problematic!!!!!!
I go to my saved Projects & none of them have Sound??????
I get a, "You're I/O has changed since the last time this session was saved.Check the I/O Setups to see what has changed. Some input's were made inactive. Some outputs were made inactive. Some bus paths were made inactive becausetheir mapped output paths are unavailable. Please visit th I/O Setup dialog for more information.
OK. I go to Setup, then I/O, I don't see anything different??? I click Default. Now I got no Tracks listed in window. I try to Undo, no luck.
I check another Project, same issue.
Who changed these Setups while everything was turned off??? What is going on???
I'm about done with Pro Tools. Going back to Tape!!!! Besides all the problems & inferior Sound, I can't depend on Pro Tools. I can't afford the down time. I can't afford to lose entire Project's. Lost Project's equal PO'd & possibly lost client's.
Can anyone tell me how to fix my current problem?
Meanwhile I have to cancel another Recording Session. How embarrassing.
Thanks for letting me vent,
Lars
I'm using Macbook Pro, PT10, Pre Sonus 16.4.2 & Glyph External Hard Drive.
Old 04-27-2013, 11:23 AM
Meads Meads is offline
Default Re: I/O Settings have changed-No sound?????
Is your interface still selected in the playback engine?
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 04-27-2013, 11:25 AM
Bill Denton Bill Denton is offline
Go to the Pro Tools manual and read the I/O section.
Pay particular note to the critical checkbox that is mentioned.
Then do a search on this board for messages from me regarding the "Default" button.
By then you should be good to go or you should have decided that Pro Tools really is not for you...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 04-27-2013, 12:16 PM
Where do I find the Manual? Is it the Search Box?
Thx,
Lars
Old 04-27-2013, 01:50 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Lars,
In your 'I/O setup' do you have 'Sessions overite current I/O setup when opened' checked? (it's at the bottom left)
There is a link at the top of the Forum page here that contains the 'Reference Manual' and it can also be found from the Help menu in PT. Ironically, one of the first things the manual deals with is finding and using this help menu. As has been mentioned to you in the past; Pro Tools is not plug and play. If you want your headaches to stop, take some of your valuable time to read the 'reference manual'. You may be pleasantly surprised how well written and informative it can be. For myself, it has been a great help in some of the confusing issues I've had.
Good luck. Have fun splicing tape :P if you decide to leave Pro Tools
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 05-13-2013, 06:14 PM
Originally Posted by dr_daw View Post
Lars,
Stuck again! The same problem is back!!! I've read & tried all the applicable Help suggestions, went through the I/O Section of the Manual, checked the "session overwrite I/O setup when opened" Box, did several defaults & re-starts. Still no sound thru External Monitors, Headphones etc.
What am I missing?
Lars
Old 05-13-2013, 07:24 PM
Did you UNcheck that box in the IO setup window?(you should). Then, while the IO setup is open, click on the Bus tab and scroll down. If you see anything in italics, uncheck that as well. People crabbed for years for more than 32 buses and starting in PT 9, Avid delivered. Unfortunately, its not perfect(yet, anyway). Also, as said, go to Setup>Hardware and make certain your desired interface IS the selected audio engine. If it keeps changing that, it could be how you fire up your system(best is to turn ON the interface before you boot the computer). If you forget and have the interface turned OFF or disconnected when you open Pro Tools, it will/may default to your onboard audio.
Old 05-13-2013, 07:32 PM
danander11 danander11 is offline
Hold down the N key when starting pt. you will launch a window that allows you to set you hardware options. I would be willing to bet, (as Albee has suggested), that you are starting pt without your interface being on/available. When that happens, your I/O changes.
And again, read the manual.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 05-13-2013, 08:42 PM
zedhed's Avatar
zedhed zedhed is offline
Before ranting about Pro Tools one should read the manual and learn how to use it otherwise one comes across as an idiot. Pro Tools works fine...yes there are bugs but in your case it's just a matter of knowing what you're doing.
Make sure you're interface is on & connected properly and bare in mind, if the proper drivers for your interface are not installed problems will arise. As mentioned go to Pro Tools>Setup>Playback Engine and make sure your interface is selected.
Then got to Pro Tools>Setup>I/O Setup>Input Tab & click Default then do same on Output Tab. You can now customize your I/O setup, renaming I/O's & Busses appropriately so they make sense if you wish.
UNCHECK 'Sessions overwrite I/O'
Once you've checked that everything is working properly go back into I/O Setup and Export this setup; name and save it to a logical location, if you ever have problems again open Pro Tools>Setup>I/O Setup and import this setup and you're good to go.
The Manual (Reference Guide) is installed with PT installation so it should be available in the Help menu within PT, or just google it if you can't find it.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 05-13-2013, 11:08 PM
I have checked all connections, ok.
Start up sequence, External Hard Drive, Pre Sonus finally Macbook w/ PT10.
I have done all of the above recommendations. I have read I/O section in Manual.
I have done several Re-starts.
Above Pan control on Mixer screen it says "no group", when I click, it says "No active Mix Groups". Is that the problem? What to do?
Thanks,
Lars
I/O settings changed Adept Pro Tools 9 5 03-07-2012 04:57 PM
I/O settings changed when upgraded to 8.0.4 benadams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-06-2010 12:51 PM
I/O Settings Changed??? Please Help!! TeleKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-20-2004 05:42 PM
I/O settings changed? Elvisaintme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-31-2004 11:32 PM
I/O Settings changed? Elvisaintme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-18-2004 11:46 PM
