Old 09-08-2007, 04:37 PM
gw sound gw sound is offline
Default Bounce to Quicktime- could not finish bounce ?
I am trying to bounce to a quicktime movie and every other time or so I get a message hat says it cant finish because a volume was missing (-35). Anyone know what that means?
Old 09-08-2007, 04:51 PM
Default Re: Bounce to Quicktime- could not finish bounce ?
Just got it again and thought I would quote it exactly:
"Could not complete the Bounce To Disk command because Volume not found (-35).
I did bounce the whole thinge earlier without a problem. My first try gave me this message, the second time worked, and now I have tried it 2 times in a row and gotten the message. This sucks because it is a 22 minute episode. I did a test on about a minute and it worked.
Any suggestions?
Old 09-08-2007, 05:30 PM
crizdee's Avatar
crizdee crizdee is offline
Any suggestions?
It looks like The message is indicating the space allocated on the drive is not available or there's not enough space left?
And as you are able to bounce a smaller region!!!!....
Have you plenty of free drive space? Ay least 20-30% free on your audio drive! 20-30gig to write to.
Is the drive in good order?
Delete the database files on all the hard drive partitions.
Try the DAE buffer at a bigger setting! default is 2 try 4 or 6.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-08-2007, 08:41 PM
Thanks for your reply-
I am fairly certain that my dae buffer is already set to 4- I usually keep it there. I will double check. The drive is only about 2 months old and is a very good 120gig drive with about 100gigs of free space. It has been working fine. I have never done this kind of bounce before and do have a question. My video that I am working with is on a separate drive than the recording drive. This isn't a problem, is it? I always keep the video I work with on a separate drive than the one I write audio to.
Old 09-09-2007, 04:21 PM
Carl Sealove Carl Sealove is offline
Try a shorter name for your bounced movie file.
(Very short like "Bnc" - for starters)
You should be good to go.
Sealove
Old 09-09-2007, 09:43 PM
Carl-
Thank you very much! That seems to have done it. I will have to do a few more BTDs, but it worked right away. I actually had a very long name on this one, unusually long for what I normally name things.
Thanks again, I was about to get into some time-consuming work on a drive, and now my evening is free.
Bounce to Quicktime bug Arc macOS 0 01-05-2012 02:55 PM
Bounce to QuickTime Different in 9.0.3? MusoPro Post - Surround - Video 2 06-03-2011 11:24 AM
Bounce to quicktime jdm2104 Post - Surround - Video 2 12-11-2009 12:46 PM
Bounce To Quicktime ofsaints Post - Surround - Video 5 10-20-2009 05:29 PM
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-21-2001 08:28 PM
