29.97 DF to Non Drop!
I recieved some stems that were transferred incorrectly into Pro Tools at 29.97 DF. I need them to be 29.97 NDF, I only have 1 Pro Tools rig, is there a way to convert these files to play at the correct frame rate? Please let me know, thanks all.
Carlos Sanches Re-Recording Mixer Audio Circus Warner Bros. Animation http://www.imdb.com/name/nm0760851/ |
Re: 29.97 DF to Non Drop!
hiya,
drop and non-drop do not affect speed, only the measuring stick. they bothe are 29.97 frames per second. your DF stems should play in sync with a ND movie.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
yes, convert your session to NDF and resync the files using the 2-pop. if there is no 2 pop, create one using the signal generator before you change your session framerate.
Just FYI, for each hour, the difference between drop and non-drop is 3 seconds, 18 frames. So, if your drop frame session starts at hour one, retard all the audio 00:00:03:18 to get it in sync with the non-drop picture. Of course, if you are using digital video, you will have to re-spot the picture after you change the frame rate in your session.
Bob
Save early and often! (or once a day whether you need to or not...) |
pulldown and drop/non drop problems | ilinx | Post - Surround - Video | 2 | 05-16-2008 09:46 AM |
30 FPS Drop? | James Drake | Post - Surround - Video | 3 | 03-12-2008 07:41 AM |
Lining up Drop Frame to Non Drop | Roger Stauss | Post - Surround - Video | 4 | 10-10-2007 06:36 AM |
Help! Drop Frame/Non Drop | wheresmyfroggy | Post - Surround - Video | 8 | 03-30-2007 11:56 PM |
non-drop to drop - possible? | CCash | Tips & Tricks | 9 | 04-16-2001 08:01 AM |
