How to Join & Post    Community Terms of Use    Help Us Help You
Knowledge Base Search    Community Search    Learn & Support
Old 09-29-2000, 09:13 AM
MotleyGuy MotleyGuy is offline
Default Digi001 causes -6002 error and prevents BOOT UP
PII 400 / 192 RAM
Network Card (for DSL)
CD Architect
SCSI Ultra Wide controller
Miro DC30 card for video production...
When I installed the card PnP recognized it fine..and then I got ERROR -6002 Can't initialize I/O. (Ch.1-2)
The title bar of the error window is full of gibberish (??!?!?@KF). I clear the error
a couple of times and it keeps persisting. Finally, the gibberish in the title bar goes away. The card works...Pro Tools LE 5.0.1
seems to work.
When I reboot the PC, I lock up after the Win98SE splash screen.
The only way back in, is to go into safe mode and disable DIGI001 in devices.
What to do ??? >>> Please email me at "MotleyGuy@antisocial.com"
Thanks
Old 09-29-2000, 10:22 AM
DigitalWaveform DigitalWaveform is offline
Default Re: Digi001 causes -6002 error and prevents BOOT UP
i've sent you email...
Сg Wvrm
DigitalWaveform
Old 01-30-2001, 01:35 AM
aaxe aaxe is offline
I'm having this exact problem with a similar system.
Old 01-30-2001, 09:23 AM
DigiTechSupt's Avatar
Download and install Wave Driver 1.6cs5:
http://www.digidesign.com/download/wavdrv.html
Brent
Avid Audio Tech Support
Support FAQ
Old 02-05-2001, 07:58 PM
That was the first thing I tried. If I remove the digi driver before reboot, it installs upon the next boot. The only problem with this is that I have to enter in my registration number every time I start Pro Tools.
Old 02-05-2001, 09:49 PM
Vaphoron Vaphoron is offline
If it installs upon reboot you have not completely removed the old driver. Go here(http://www.digidesign.com/support/re...vr_remove.html) for directions. Then when you reboot it will not load because the driver is removed. Install the new driver and the problem should be gone.
Jason
- Jason
Old 02-06-2001, 10:53 AM
Jonhedin Jonhedin is offline
Rename the digi16.dll to something else. Reboot and voila everything is perfect. You can then rename the file back to digi16.dll and reboot. That should take care of your problem
Digi001 prevents Mac going to sleep mode in OSX audiomiditweaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 10-17-2003 09:06 PM
-6002 error on XP mobiustrip44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-29-2002 09:03 AM
6002 error...Help! Don M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-16-2002 03:01 PM
I/O -6002 error billy2112 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-07-2001 01:28 AM
DIGI001 with PC Logic gives error -6002 johans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-13-2000 09:21 AM
