Old 02-03-2014, 04:45 PM
Christer-André Christer-André is offline
Default CPTK 2 with 2008 MP, great. PT 11HDX with 2012 MP, not so great. Switch drive?
Hi guys.
Had a great system. PT 10 CPTK2 with a 2008 dual quad core 2.8 Mac Pro. Switched to PT 11 HDX1 with a quad core 3.2 2012 mac and am getting the famous 9172 errors.
The MP has really poor performance and I am also getting glitches. Can't record with less than 256 buffer size even with just a few tracks running. Been reading a lot about others having these issues. Tried a clean install, disabling spotlight, disabling dynamic plugin processing, switching of wi-fi etc, but it doesn't help.
What I am wondering is; would it be possible to take the system drive of the 2008 MP and use that with PT 10hd in the new MP? I can't use the hdx cards with the old MP, so changing the system disk (OS 10.6.8) is my only option.
I am basically thinking that since my old system worked great, if it doesn't create any compatibility problems in the transition between the old and the new MP, would doing this maybe be the solution?
Could also install 10.6.8 on a ssd drive and reinstall everything again, hoping that it's the OS that's causing all these problems.
Old 02-04-2014, 04:36 AM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default Re: CPTK 2 with 2008 MP, great. PT 11HDX with 2012 MP, not so great. Switch drive?
Putting your 2008 MP System drive in your 2012 MP should work perfectly fine. Just swap it and boot.
If you leave your original 2012 System drive in, be sure to hold OPTION while booting (Through chime) to select the appropriate drive to boot from
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 02-04-2014, 02:16 PM
Thanks.
Appreciate it.
I'll try that.
C
Esata Hard Drive Runs GREAT With PT8 Benoni 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-25-2009 03:39 AM
PT8 = great Raggi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-31-2008 03:35 AM
URS Plug-ins - Great Sound, Great Service rockrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-18-2004 10:27 AM
Digi and everyone - I've got a great idea for a great new feature [Benjamin] Tips & Tricks 65 10-13-2002 08:26 PM
Great Take.. Way in the Red augiealexander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 07-27-2001 01:01 AM
