Old 10-11-2007, 12:20 PM
Sascha Pendegraft Sascha Pendegraft is offline
Default Multiple songs per session...
I am recording some lectures for school and want there to be a different CD track for each section without having to open up a new session for each one. It will all be one long lecture, but I need to insert CD tracks (Yes, I am stating the same thing two different ways so that there isn't any miscommunication regarding what my need/ questions is). How do I do this in a session? I haven't even looked in my manual yet, nor have I even searched the menu options...I just need a quick answer, if possible. Thanks y'all.
Old 10-11-2007, 01:06 PM
spkguitar's Avatar
Default Re: Multiple songs per session...
Normally, you don't do this in a session, you do it with the CD burning software.
Old 10-11-2007, 07:09 PM
WaveLab and SOund Forge(or is it sonic foundry?) both let you insert track markers in a long piece of audio. When you burn the disc, make sure you select whether you want space or no space(i.e. silence) between "tracks".
Old 10-12-2007, 01:59 PM
Barnabas Barnabas is offline
I set up markers at each track break. Then I select the audio from the start marker to the end marker, and bounce each song (track) one at a time. Then I import these tracks into my CD burning program and set the time between tracks to zero seconds.
www.barnabas.com Barnabas MultiMedia
Old 10-24-2007, 11:06 AM
sw rec sw rec is offline
CD Architect will let you drop track markers, and even track index markers, so you could have multiple cue points within each track. NERO also gives you that option to drop markers, but since the release of version 7, I haven't even been able to get NERO to load. Had to switch to Roxio, but don't see a "drop track marker" option.
Old 10-24-2007, 11:00 PM
MJarzabek MJarzabek is offline
Open your session, import the audio from the lecture. As it plays insert markers where you want the tracks to start by hitting "enter" on the numeric pad. Your markers will be set up in numerical order.
Once you have the markers set up, bounce each song by selecting the start and end marker. For example, if your song starts at marker 1 and ends on marker 2, hit ".1." hold down shift and then ".2." That will select the audio for track 1. Track 2 would be ".2.", hold shift, and then ".3." and so on.
Once it is selected, bounce it to disk. Do this for each song/track and you should be good.
Hope this helped,
Mike
Still working.
Breaking up multiple songs in one session into multiple sessions? rmandelbaum Windows 10 08-14-2013 11:05 PM
Bit of an odd one maybe... multiple songs, one session AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-27-2010 06:41 PM
Mixing Multiple Songs In One Session Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-20-2007 05:52 PM
Multiple songs...one session.... LFarah Pro Tools M-Powered (Mac) 2 11-20-2006 10:45 AM
Multiple songs in a session or one for one? Jeff Hodges Tips & Tricks 5 02-05-2002 12:59 PM
