Old 10-24-2014, 01:14 PM
thegame15 thegame15 is offline
Default Re: Yosemite and Mbox 2 Drivers (Good news so far)
Glad you guys got up and working :)
Macbook Pro 13 inch Mid 2010, 2.4 GHz Intel Core 2 Duo, 8 GB 1067 MHz DDR3, Yosemite OS X 10.10.3, Mbox 2
Old 10-27-2014, 04:34 PM
djonz210 djonz210 is offline
Thanks orchetect !! I followed your steps and it worked for me! I'm running the old digidesign mbox 2 mini , new iMac and yosemite.
Old 10-30-2014, 03:31 PM
ITJ57 ITJ57 is offline
Originally Posted by orchetect View Post
Thanks for the update. I too have an Mbox 2 mini with the 10.3.3 drivers installed, then upgraded to Yosemite and the device disappeared - no green LED light, "Unable to connect to Mbox 2" in the preference panel.
I will tinker with the 10.3.3 driver like you suggest and see if I can coax it into working again.
Cheers
EDIT: Aha! Success! (For Now)
Here's what I did to get the MBox 2 mini to work:
1) Manually uninstalled the driver components (delete, then empty trash):
• /System/library/extensions/DigidesignMbox2.kext
• /System/library/extensions/DigidesignMbox2Boot.kext
• /Library/Audio/MIDI Drivers/DigidesignMbox2MIDI.plugin
• /Library/Startupitems/Digidesign Mbox2
• /Library/Startupitems/DigidesignLoader
2) Opened System Preferences, right-clicked "Digidesign MBox 2" icon, selected "Remove "Digidesign MBox 2" Preference Pane"
3) Rebooted
4) Installed Mbox 2 Driver 10.3.3. After, the computer rebooted.
5) Switched the physical USB port the MBox was connected to, then after a few seconds the green LED came on and it's working normally now.
This worked for me.
THANKS!
Old 11-02-2014, 11:23 AM
ShaneCurran ShaneCurran is offline
Cheers
3) Rebooted
Do I still need a USB hub for this to work? I followed the instruction and I have a light, and I can hear the input if the mix is to the left, but no audio from my monitors. So do I still need to get a USB hub???
Old 11-02-2014, 02:15 PM
zzzaccount zzzaccount is offline
Thank you orchetect. I followed your instructions and it worked like charm
Running OS X Yosemite 10.10 on MacBook Pro (17-inch, early 2011)
2.2 GHz Intel Core i7 (Quad-Core)
with digidesign MBox2 mini
You're a life saver!
Many thanks again.
The only thing is that every time the computer restarts I have to unplug & replug the MBox2 Mini.
  #16
Old 11-06-2014, 02:21 PM
backporch backporch is offline
This was working for me earlier, now I can't get the light to come on at all, and the control panel isn't seeing it either.
I updated to the 10.3.9 driver and it made no difference. Tried again, reinstalling as above, and nothing....
It's possible my unit is dead.... nothing shows up in Console either...
  #17
Old 11-06-2014, 02:44 PM
OK, so I just repeated the process, this time with the 10.3.3 driver, and it's working again! I guess there is something wrong with the 10.3.9 driver, or there's some other magic happening... the only other difference was this time I did the reinstall with the unit unplugged.
  #18
Old 11-19-2014, 05:40 PM
Bad news again, I've been getting kernel panics in Yosemite, and it appears the mbox 10.3.3 driver is to blame....
  #19
Old 11-20-2014, 02:35 PM
Mike Farnan Mike Farnan is offline
I have a new iMac Retina i7 running Yosemite and an Mbox 2. orchetect's fix worked for me to get PT 10.3.7 working (although there are a lot of visual glitches with the menus). However, it completely killed PT 11. It won't even boot up now.
It's truly disgraceful how slow Avid is at updating their software. They should spend less time coming up with new pricing schemes and get to work on making their software compatible with operating systems that they know about a year in advance.
Michael Farnan
Desiderata Media, Inc.
  #20
Old 11-21-2014, 03:11 AM
willaddy willaddy is offline
Hi installed the 10.3.3 drivers and everything seems to be working, but the sound is awful. Really distorted, just wondered if theres something I have done wrong that anyone could help out with?
Good news here with PT9 Chief Pronto Pro Tools 9 16 11-08-2010 01:51 PM
AIR Blog - Bad News... Good News RussUK Virtual Instruments 3 04-01-2009 04:19 AM
Good News and Bad News....original Mbox & Pt Le 6.4 captain54 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-02-2007 10:52 PM
I have some very good news! Swaphappy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 12-20-2003 10:28 PM
Good news for us! who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-06-2003 12:29 AM
