HDX on Catalina
Have you read the Pro Tools 2020.3 Read Me - Mac PDF???
I found this Pro Tools | HDX and Pro Tools | HD Native Systems HD Driver may not load on macOS Catalina after installing Pro Tools (PT-257898) When installing Pro Tools version 2019.12 and HD Driver version 2019.12 or later on macOS Catalina, HDX cards may not be detected when rebooting the computer. To correct this issue, do one of the following: • Manually load DigiDal.kext after every boot; Launch the Terminal and enter: sudo kextload /Library/Extensions/DigiDal.kext • For a more permanent solution, force an update of the pre-linked kernel via Recovery Mode in the Terminal: touch -c "/Volumes/Macintosh HD/System/Library/Extensions" Seriously????
Mac Pro (Mid 2010) Six Core 3.33GHz macOS 10.14.6 MSI Radeon RX 560 Pro Tools | HDX, HD I/O 16x16, HD I/O 8x8x8 Pro Tools Ultimate 2022.9 MacBook Pro (Mid 2012) i7 2.3GHz macOS 10.15.7 Pro Tools 2021.12 Apogee Duet |
Re: HDX on Catalina
2019.12 was obviously rushed release to get initial Catalina support out. Just update to 2020.3 which everyone seems to be liking
Re: HDX on Catalina
The OP points out this is still an issue in 2020.3.
https://lukehoward.com/ |
Re: HDX on Catalina
I thought the issue was about 2019.12 software version even with later driver
Re: HDX on Catalina
Ah, right you are.
HDX in new Mac Pro/Catalina | rourketown | Pro Tools 2019 | 11 | 08-24-2020 03:40 AM |
Catalina on Mac Pro 5,1 | the.engineer | macOS | 15 | 01-24-2020 06:06 PM |
PT and Catalina | gub | macOS | 3 | 12-21-2019 12:48 AM |
Catalina | cqd | Pro Tools 2019 | 10 | 10-09-2019 01:37 PM |
Catalina | Ryan Young | Pro Tools 2019 | 6 | 06-06-2019 10:20 PM |
