using reason adapted as a plugin
I have installed the version of reason adapted for digidesign that came with my mbox2 and I am having trouble using it in a pro tools session. I am trying to use an instrument track, select reason's redrum as the instrument, and then bus it to an audio track and use it for a percussion piece in a session I am working on. Basically, protools doesn't recognize reason as a plugin, but I have it on my computer. Is there anything I should do to enable reason as a plugin?
Re: using reason adapted as a plugin
Actually, Reason CAN be used on an Instrument track - those instructions were created before Instrument tracks were introduced.
If you're not seeing Reason in your plug-ins list, it could be because you're not running the minimum required version for your system. Can you please post system details so we can determine if that's the case? You may want to read the Help us help you thread as well. |
thats probably it - my version of reason is Reason adapted for digidesign version 3.0.5.
Great Price - Reason Adapted To Reason 4 - $239 / EUR 199 | BPlayer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-17-2007 10:05 AM |
ugrading reason adapted 2.5 to reason adapted 3.0 | jimmyd3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-11-2007 06:10 PM |
Reason Adapted vs Not-Adapted...how does it work? | arthur s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-10-2006 01:22 PM |
Will Reason 3.0 Read Reason Adapted Files???? | remaofaes | Pro Tools TDM Systems (Mac) | 2 | 01-08-2006 12:33 PM |
Upgrade PT Reason Adapted to FULL Reason ...Price? | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-09-2003 07:04 AM |
