Old 08-19-2003, 05:18 PM
Susurrus Susurrus is offline
Default Recovered harddrive question(s)...
I work at a Post facility in Burbank, and we recently had a System drive on a Mix+ go down. We have since put in a new harddrive, but we have yet been able to re-authorize everything. So I took the liberty of trying to recover as much data as I could from the drive, and I think I have about 90% of it.
My question is, What do I need to save? Particularly in regards to plugs authorizations. Are there certain folders I should look for and save?
I thank you for your help and time in advance.
[EDIT: I guess I don't need my sig twice...]
Keith Wells
Sr. V.P. Operations
Juniper Post, Inc.
Burbank, CA
Old 08-19-2003, 05:27 PM
Default Re: Recovered harddrive question(s)...
You will not find your authorizations stored in any folder. Your authorizations are stored on hidden partitions of the disk. This is what makes it possible for you to initialize a drive and still recover your authorizations. The initialization doesn't affect the partition in question. Mac OS X will corrupt these hidden partitions, rendering your authorizations useless (and sometimes unrecoverable even).
Since you recovered data off the drive, it is likely mounting and functioning (barely at least). This is the perfect (and perhaps last?) opportunity to get out your key disks and pull the authorizations off. If you can't do this, you will have to use your backup authorizations.
New External Harddrive question theproducer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-16-2010 06:25 PM
harddrive question usd Pro Tools TDM Systems (Mac) 0 07-10-2008 05:52 AM
External Harddrive Question dadio2002 General Discussion 2 08-19-2005 07:57 PM
External Harddrive question EricFuller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-09-2004 11:27 AM
harddrive question????? phaseout 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-05-2002 10:24 AM
