Old 05-30-2020, 06:29 AM
Cryos's Avatar
Cryos Cryos is offline
Default Drive not seen in 2019.12, seen with 2019.6
I have one drive that 2019.12 won't see or mount yet if I use an older version of protools 2019.6 it sees the drive just fine.
Drive in question mounts just fine on the mac desktop and is 100% accessible.
I've checked the drive with disk warrior and it's perfectly optimized accoring to DW.
I've been in contact with AVID tech support ( I have an active support plane and don't want to upgrade just yet!) And avid aren't of any help!
I can post all the solutions AVID have suggested but in the end none work!
So what would explain 2019.6 seeing the missing drive without a single glitch yet 2019.12 wont even see it ?!
I'm on Mojave
Macpro late 2013 3.5 Ghz
64 gigs ram
Also note I have a 2nd machine macmini 2018 same OS. and the drive is seen without an issue in both 2019.12 and 2019.6
I'm using an external bay drive enclosure via a Lacie Esata hub.
The bay drive also has USB 3 on it and have tried connecting via that and same issue. Very odd.
Also this started happening in the last month. Wasn't an issue before.
Sent from my SM-N950W using Tapatalk
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
HDX Ultimate - 2019.10 7 2019.12 - video export issues anguswoodhead Post - Surround - Video 2 03-09-2020 02:33 AM
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
2019 iMac vs 2019 Mac Pro Peterjk Pro Tools HDX & HD Native Systems (Mac) 7 01-14-2020 12:23 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
