Old 08-30-2008, 10:32 AM
haney411 haney411 is offline
Default MBox problem - bad hiss on 1/4" input, but XLR input is ok!(?)
I'm using MBox and if I plug in to the 1/4" input on either channel 1 or 2 I get massive hiss when I try to record. However on either channel the XLR input is just fine. I've tried several 1/4" cables, different instruments, etc. I get the same behavior using either ProTools or Ableton Live. This hiss wasn't always there, I've recorded for years w/ this mbox and this has just started happening, with increasing frequency until now it happens almost all the time. Anyone have any experience with this or suggestions??? The hiss is on the track itself, and so comes through on headphones, monitors, etc.
Thanks!
Paul
Old 08-30-2008, 07:08 PM
rqstudio rqstudio is offline
Default Re: MBox problem - bad hiss on 1/4" input, but XLR input is ok!(?)
Thanks!
Paul
I'm not sure what MBox you have, but aren't the RCA's for SPDIF?
Old 08-31-2008, 10:22 AM
Yes, but I'm not using the RCA in/out at all. I have the original flavor of MBox. I've tried a different computer, tried different power outlets, and every permutation of the setup results in the same thing: the 1/4" input being unusable, and the XLR being fine.
MBox 2 WaveForm not recording right/"normal" on Input 1 EDF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-16-2011 09:08 AM
Pro Tools Mini Brand New User, Mic Input Hiss randymarcell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-23-2010 10:08 AM
192 Analog Input Input Problem, Very Frustrating lenkarm Pro Tools TDM Systems (Mac) 7 04-20-2010 09:27 PM
Mbox won't recognize A/D converter - SPDIF "input path not available" ? casadelsueno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-16-2010 01:48 PM
Very odd input problem on Mbox. el_ahrairah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-21-2006 05:44 PM
